Mirror Glaze
  • Mirror Glaze
    I just bought a Porter Cable orbital buffer and using mirror glaze professional show car glaze number seven. as i was polishing i noticed that the glaze would build up in certain spots and when i would go to wipe off the glaze some parts were difficult to rub out.
    what am i doing wrong?
    i have used this glaze before and the bottle that i got seems to be a different consistency than the last bottle.
    Re: Mirror Glaze
    After looking at the Mike Phillips video... the #7 glaze should be wiped off in two stages. First wipe off the whole car trying to get most of #7 off, but not completely off. Then start a completely 2nd phase, where you wipe off again. You doing this while constantly using different parts of the plush MF towel for each section.
      Re: Mirror Glaze
      Why are you using #7?
      That is, what are you trying to accomplish with the paint?
      What speed are you running the polisher?
      #7 is primarily for creating gloss on a finish that is perfect, is that what you're trying to do?
        Re: Mirror Glaze
        first i clay the car then i used a per cleaner wax, than i use the number 7 then the high tech yellow wax. im trying to bring out the color in the paint. the speed i use on the buffer is 4.
        i want the car to have that wet look.
        i used to do this by hand but it was taking too long.
        the color of my car is WR blue if that helps.
        thanks
        05wrxguy
          Re: Mirror Glaze
          when it comes to applying #7 LESS IS MORE the setting is about right i tend to use 3 and a half, but spread it thin and really work it in with just a little pressure like 5 lbs and work it in ohh did i mention work it in this will allow for easy removal
          custom mobile detailing located in central maine
            Re: Mirror Glaze
            05wrxguy,
            Since you’re local you should come on down to a Saturday class. They're great fun.
            PC.
              Re: Mirror Glaze
              saturday classes?
              what?
              where?
              when?
              How much?
                Re: Mirror Glaze
                Originally posted by 05wrxguy View Post
                saturday classes?
                what?
                where?
                when?
                How much?
                Open Class - January 27th
                What: Detailing Class
                Where: At Meguiar's Corporate Office
                When: January 27th
                How Much: You are required to bring enthusiasm and high expectations.
                Be there are be square...
