Meguiars Glass Cleaner or Stoners Invisible Glass?
  • Meguiars Glass Cleaner or Stoners Invisible Glass?
    For the ones who have used Meguiars Glass Cleaner Concentrate and Stoners Invisible Glass.... What do you prefer? I have IG and like it but I am getting low should I change to Meguiars?
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
    I like Meguiar's better then Stoners, but I like Sprayway just as much as Meguiar's.
    Meguiar's is a much better value though so I will probably stick with that.
      I've used both and perfer megs over stoners..........plus the one gal con. is enough to mix serveral sprayers around the house, ect.
      2000
      2019 GMC Sierra
      1500 AT4
        Do you dilute meguiars? If I get a gallon could use it in the house as well!
        Brandon
          yes, off the top of my head it's a 6:1 ratio, should last you quit a while if it you share with the house.
          2000
          2019 GMC Sierra
          1500 AT4
            I'll be testing soon.
              Just to chime in,
              The dilution for Glass Cleaner is 10:1, that is 10 parts water to one part Glass Cleaner. Thus, 1-gallon of concentrate will make 11 gallons of glass cleaner.
              One of my favorite products. We keep 2-3 32 ounce bottles in the house all the time for cleaning mirrors, windows and even counters. Works great.
                opps! I knew I should of waited to post that till I got home to check. but hey 10:1 is even better! sorry for the misinformation.
                2000
                2019 GMC Sierra
                1500 AT4
                  I like the Meguiars better also. I used to buy the stoners but the megs works better and MUCH cheaper. Not to mention you dont need as much space to store it.
                  If you dont play you CANT win!
                    it works so good on that chevelle that it looks like nothings there at all.
                    2000
                    2019 GMC Sierra
                    1500 AT4
                      I **** at math how would you properly dilute Meguiar's Glass Cleaner let say in a 32 ounce spray bottle? Thank's..
                        Hi George,
                        You would just take your total amount in a bottle, this case it is 32 ounces, and divide by 11 (since it is 10:1 diltion)
                        For example: 32 / 11 = 2.9
                        Round up... and you get 3 ounces of glass cleaner + 30 ounces of water (10 x3) = 33 ounces of ready to use glass cleaner...
                        Our secondary bottle have the dilutions marks already on them, which makes it very easy. Those will be ready to ship very shortly.
                        In the meantime, just use secondary bottles that have measurment marks (ounces) on them.
                        Mike Pennington
                        Meguiar's, Inc.
                        800-854-8073
                        mpennington@meguiars.com
                          Thank's Mike, appreciate your help!
                            My older style secondary bottles have the dilution marks on them as well.....Make it so simple my wife could even mix it right.
                              the new bottle are a big improvement. They also have the marks set up so you add the water first and then the product. Makes more sence and its much harder to screw up the dilution ratio.
