Mid-detail!!!! Please help
  • wkbrdr03
    replied
    Re: Mid-detail!!!! Please help
    Yea it is all single stage
  • Murr1525
    replied
    Sure looks good. Did you find the whole car is single stage, or just that section? Not that it matters at all, all your work is done the same way.
  • CharlesW
    replied
    Originally posted by wkbrdr03 View Post
    hey lydia...do you think that i could go deeper w/ scratchx on the section shown...i did 3 passes
    Keep in mind that single stage paint is a finite quantity same as clearcoat.
    When you polish to get rid of swirls/scratches, you don't remove the swirls/scratches, you level the paint around them by removing some of it.
    It would take a lot of polishing, but it is possible to go through single stage paint and have primer showing. That is not a good thing.
  • Lydia
    replied
    I think you could go deeper. I've done six passes in one spot before. I'm not sure if you will be able to remove those scratches though...if you run the edge of your fingernail over them, does it catch? If it catches you probably won't be able to remove the scratch, but you can probably diminish the appearence of it.
  • wkbrdr03
    replied
  • Lydia
    replied
    No you do not need to do anything different. Keep up the great work.
  • wkbrdr03
    replied
    yea...i used a clay bar...i just found out that it is for sure single stage paint...do i do anything differently now?
  • doopy
    replied
    did you use a claybar before Scratch-X ? I think it's dirt from the paint
  • wkbrdr03
    replied
    ok well you guys can draw your own conclusion before i move on...
    before...
    applicator...
    after...
  • hondaprelude98
    replied
    I have a black car and when i used the product it did not turn black, but liek the other ppl said if it is glossy then dont worry, it could have been dirty maybe
  • wkbrdr03
    replied
    ok so i have done about a 3x2 area on the hood and it looks good...not great but good, swirls have completely been removed, just some isolated scratches. i am waxing it now just to double check but it def seems much better.
    the only problem is that one applicator is almost completely black, should i keep going cuz it looks better?
  • CharlesW
    replied
    Just another thought.
    The paint may have been meglected to the point where it actually had a layer of dirt that the Scratch-X is removing.
    The comment made, "it seems like it pulled some up and then it was done, and it seems more like a tint than the actual black paint." could be indicative of dirt on/in the paint.
  • wkbrdr03
    replied
    thanks mike...back to the car...
  • Mike Phillips
    replied
    Sounds right. Don't worry, it will turn out great!
  • wkbrdr03
    replied
    ok...thanks for your help...at least now i know what the options are...i am very confident that it is all factory paint,bought used but lady had all work done at dealership and there are lots of chips in the hood which tell me its not a new hood
    so here is what i'm going to do...
    gonna try to polish up the same spot on i'm working on, and then go to another spot on the car and see if it pulls anything up
