dilution of D111 shampoo plus
  • dilution of D111 shampoo plus
    Hey Mike,
    we have a little question about the dillution of D111 shampoo plus
    its says 128 : 1 what means
    128:1 means 128 ounces (= 1 gallon) of water and one ounce of shampoo plus".
    1 gallon = 3.78 liter
    4 gallon = +/- 15 liter
    1 ounce = 29 ml
    4 ounces = 116 ml ofwel 11,6 cl
    so in european term, when we fill up a bucket around here from 15 liter its going to be 116 ml of shampoo, we feel that is a lot of shampoo ? what your meaning about this?
    Shining regards
    Sven
    Meguiar's Exclusive importer for Belgium
    http://www.meguiars.be
    Re: dilution of D111 shampoo plus
    Numbers look right to me.
      Hi Sven,
      I use Shampoo Plus all the time and have found that the stated dilution rates are too high i.e. where you say 116ml I would substitute 80ml which I find is more than enough, especially if you are going to clay, at 100ml + I have found that to cause problems as it leaves an oily solution behind which can make it dificult when claying and indeed polishing etc asswell.
      Bryan
        One ounce to one gallon is normal for all of our washes except Hyper Wash which is 400:1
        You can dilute down to suit your preference as Bryn states he does, most people tend to go the other direction and over use their car wash solution and then run into problems with streaking.
          this Shampoo Plus meguiars
          alberto gorin
          known as gorin002
            Thanks all. I questioned Sven about the dilution ratios.
            I noticed that NXT car wash is also 40ml / 5 L so the same bucket of 15 L also results in 120ml or 12 cl NXT car wash solution.
            showroomglaze.net
