Glass Cleaner Comparison Needed
  • Glass Cleaner Comparison Needed
    I need some input on the comparison between Meguiar Glass Cleaner (D12119) and NXT Generation Glass Cleaner. The NXT doesn't mention cleaning vinyl for but the (D12119) does. Vinyl fog drives me crazy. Thanks
    Re: Glass Cleaner Comparison Needed
    The both work exceptionally well for removing vinyl fog, be sure to use a clean cloth to remove and if vinyl fog is really bad redo the window using a second clean cloth so you don't simply transfer the removed vinyl fog, (an oily film), back onto the glass.
      nxt glass cleaner is the finest glass cleaner i have used in the 6 years i have been in bussiness!!
      i cannot get it to streak! i spray one micro with the cleaner untill damp and then follow with a dry cloth. this way i get no overspray on freshly cleaned surfaces.
      i did my own windows this way in the direct sun and it would not streak !!
      mike
      The Shine Shop
      410-833-1632
      Reisterstown MD
