I have seen post from individuals who claim to use a foam gun i.e. Foamaster. In searching the Internet, I see that these guns run $50 +, is there a less expensive alternate to the gun?
Foam Gun
Re: Foam Gun
Well, I have the 1qt, and it about does one car. I have had to occaisonaly refill, so for a bigger vehicle, or if you want to be certain, maybe you want bigger.
And definately the brass adjusstable. Kind of depends what soap conentration you use, but the adjustable gives you some lee-way.2017 Subaru WRX Premium - WR Blue
Re: Foam Gun
Originally posted by Murr1525 View PostAnd definately the brass adjusstable. Kind of depends what soap conentration you use, but the adjustable gives you some lee-way.
Thank you in advance!
Zoran
Re: Foam Gun
Originally posted by Murr1525 View PostI am sure both work fine, I went with the brass for durability, and it at least looks easier to clean... and because Accumulator told me too...., but if they don't have hidden differences I am not aware of, are practically identical, my gut feeling tells me to go with Foamaster II as I have impression it will be more durable, thin attachment bottle is hanging from on regular Foamaster (vs. neck of bottle going straight onto rest) makes me uncomfortable because thin metal to plastic connection usually lead to jiggling and cracking of plastic, and metal-to-metal sliding pin will be either too tight until it wears down, and then too lose, or too lose from the get go.
Thanks for helping me make up my mind.
Re: Foam Gun
It actualy looks like there is a brass connection in the lid of the bottle, so it isnt too dangly, but I dont think there is any big differences. Now with the bigger liquid bottle, that might be something. It would also matter if you used certain chemicals. But you can always ask when you call, just to verify. They seem pretty knowledgable.2017 Subaru WRX Premium - WR Blue
Re: Foam Gun
Originally posted by Murr1525 View PostNow with the bigger liquid bottle, that might be something.
Originally posted by Murr1525 View PostBut you can always ask when you call, just to verify.
Re: Foam Gun
You can probably order a spare bottle in the other size.
I ordered some Quick Connects and Shut-Offs as well when I got mine. But dont get the Full Flow connectors though, the spinning cuff doesnt work right with weight hanging on it. I actualy just use a solid one-piece one from Home Depot now. But I love the quick-connects.2017 Subaru WRX Premium - WR Blue
Re: Foam Gun
here is a movie of the gilmore foam gun in action ,it is using poorboy's 50% sss
and 50% bug squash just postng vid to show how the foam gun works
Jeff
Re: Foam Gun
Originally posted by RAYJAY View Posthere is a movie of the gilmore foam gun in action ,it is using poorboy's 50% sss
