the hard areas to clean and polish, alot of the cars these day have alot of curves and indentations, do them buy hand? or can you use a polisher, since it says to stay off high areas with the polisher, I would assume to do them buy hand.
detailing small areas
Re: detailing small areas
It al depends in how much you trust your skills with the machine, and also how hard is the area to work. for example, if you detail small areas like the painted parts between the headlights or tail lights, then it could become pretty hard to do it by machine, and yeah, it would be better (and safer IMO) by hand.
I don't know if you have heard bout the powerball system form mothers. maybe that would be an alternative for small areas.
BTW when you buff sharp areas or curves, just be sure to do it carefully or else you might get a paint burn when using a rotary.
Hope this helps" Sometimes logic is your friend (Mike-In-Orange)"
I was going to ask the same question. My front bumper has some spots on it and I need to use #80 on it. Will it still break down if I use it by hand? How long do I need to go at it?Current Jeep: 2004 Jeep Liberty with stuff
Originally posted by Mike PhillipsLive on the edge... try something new, try NXT Tech Wax 2
yup, it will. as far as I remember, the only meguiars products that will break down by rotary buffer are the paint cleaners and compounds (fine/med/heavy cut cleaner and both compound cleaners), so there shouldn't be any problem at all
and about the spots, you'll have to keep on going until you remove the defect, unless you see that the defect is too deep to remove it safely.
what kind of spots do you have?" Sometimes logic is your friend (Mike-In-Orange)"
Originally posted by Chex View Postyup, it will. as far as I remember, the only meguiars products that will break down by rotary buffer are the paint cleaners and compounds (fine/med/heavy cut cleaner and both compound cleaners), so there shouldn't be any problem at all
what kind of spots do you have?Current Jeep: 2004 Jeep Liberty with stuff
check out this link
I found it way good, and it explains very clearly how to deal with this particular problem.
after reading the post, I'd suggest you if scratchX doesn't do the job, to use M83 (dual action cleaner polish) to try to remove it. however, I think scratchX will do the job if the spots are not that deep.
If you feel a little unconfident with M83, keep on with scratchX until the spots are removed or barely visible
