#83 with a Light Cutting or Polishing Pad???
  • #83 with a Light Cutting or Polishing Pad???
    So I still haven't purchased some W8006s
    So for now, I'm trying to work with these LC pads
    I'm applying #83 to my 2001 Ford Mustang using LCs light cutting pad, possibly the equivalent to the maroon W7006. I understand that this is quite an aggressive combo, however I am still showing a good amount of swirling.
    I'm using only a small bead of product around the edge of the pad, working it in at a slow arm speed with a PC speed setting of 5, and I'm using the correct pressure on the head of the polisher. I let the product work in for about 5 minutes making roughly 4-5 passes
    My results are and slight haze from the cutting pad, that's easily fixable with the #80, but the swirling is still showing.
    What could I be doing wrong?
    Overapplication?
    Not letting the diminishing abrasives break down?
    How hard is ford clear coat?
    -Brad
    Shine Masters Pasadena, CA
    shine-masters.com
    Re: #83 with a Light Cutting or Polishing Pad???
    Overapplication?
    Hi GTBrad,
    Why don't you make plans to come to this weeks Meguiar's Garage, bring your LC pads and let us have a stab at isolating the problems and showing your the solutions.
    I'll create the sign-up thread right now.
      THANKS MIKE
      Sounds good, I'll see if I can make it out there!
      -Brad
      shine-masters.com
        #83 does dust with the orange pad. it doesn't dust with a W8006, I have no idea why but i know it as a fact. I was using a new orange pad and #83 on a cool surface and it started dusting almost right away.
        Patrick Yu
        2003 Honda Accord
        2008 Honda Accord EX-L V6
