Remove Chewing Gum from Paint?
  • Remove Chewing Gum from Paint?
    Wife comes home yesterday and tells me about her friends BMW, that someone rubbed chewing gum into the finish in a long thin line. Apparently it's hardened and collecting foreign matter. LOL
    Her friend wouldn't dare hire me to work on the car but she wanted my advice anyways/
    Just curious what advice people might give? These are some of the things I might try--not in this order.
    Claybar?
    Bug & Tar Remover?
    Peanut Butter/Peanut oil?
    Goo Gone?
    APC and Pressure washer?
    Richard Lin
    ShowCarDetailing
    5548 E. La Palma Ave
    Anaheim, CA 92807
    toll free: 866 707 9292
    I had to remove some gum from my car last year after some punk spit it out onto the hood.
    It was hardened but it was in a small glob. I took a cotton ball soaked in Body Solvent and let it sit on the glob for about a minute to soften it up, then I wiped it off with a soft cloth with some Body Solvent on that. Got most of it on the first wipe and repeated the process a second time. Followed up with a clay bar and was back to normal. You could probably use bug and tar remover or goo gone in the same manner.
      Goo gone would work on a chewing gum just make sure that you let the it soak for a few minutes
        Thanks for the info! Always excellent advice on MOL!
        Richard Lin
        ShowCarDetailing
        Anaheim, CA 92807
          If its on a flat part, you could always get some plastic razor blades that are paint safe to get it off. Soaking it in bug/tar or some other solvent might be the safest for the paint though.
          -Brian
          2007 Obsidian Black IS350
            I apparently ran over a piece of ABC gum (already been chewed!) and kicked it up onto my lower rear valence. By the time I found it it had pretty well dried up, so the bulk just sort of peeled off, but it did leave a thin, narrow strip left. I had some Gunk foaming Bug & Tar Remover on the shelf so I grabbed it, gave a quick spray and the last of the gum came right off.
            Of course, it might have helped that I had a couple nice coats of #20 on my car to begin with!!
              Re: Remove Chewing Gum from Paint?
              Place a tea towel over the gum then put a load of icee on it after about 5 mins take of the ice and tea towel, the gum should have gone hard, VERY GENTLY peel it off, it might peel eeasily or it might crack off, if you find that some of the gum isn't comeing offf you need to put the tea towel and ice back on it repeat untill all the gum is off then clean using a leather cleaner. Make sure that you use the tea towel don't put the ice directly on the leather
              Commercial link removed per forum rules.
                I would hope he removed it by now...
                  Just to note, we've removed the commercial link in your Signature Line as you're breaking forum rules.
                  Please abide by our forum rules, consider this your polite warning as stated in our code of justice for breaking forum rules.
                  Forum Rules
                  Here's the portion on signature lines.
                  Signatures Rules Level I
                  1. No Clickable Links Allowed to Commercial Websites
                  2. No Clickable Links Allowed to Other Discussion Forums
                  3. No Phone numbers or Email addresses will be allowed
                  4. No signature photos allowed (this option is not enabled)
                  5. Nothing rude, crude or impolite will be allowed
                  Signatures Rules Level 2 - After 30 Relevant Posts
                  1. Clickable Links Allowed
                  2. Phone numbers allowed
                  3. Clickable email addresses allowed
                  4. No signature photos allowed (this option is not enabled).
                  Justice for Breaking the Rules - Color Code:
                  We are human and we all make mistakes, however, there will be consequences for your actions as follows:
                  Blue = Polite warning via email to remind you of the rules.
                  Green = E-mail warning and possible 1 to 7 day suspension.
                  Red = You will have banned yourself immediately with little or no warning.
                    Nail polish remover and a soft cloth will do it, easy!
