I can get M09 today from local PBE,they do not have 82, or order 82 from ADS. Is there a difference in there abliity to remove swirls. I have some fine polishing left to do.
I get lost in all the numbers???
According to the Meguiars catalog, #82 is formulated for fresh paint. So if you are not working on fresh paint, I would probably go ahead and try the #9 first since it is readily available to you.
That is just my opinion.
They are both about the same aggressiveness according to the scales on the bottles.
#82
FEATURES:
• Formulated for fresh paint
• High performance polish eliminates swirl marks fast
• Specially blended polish with cleaning power removes
fine scratches
• Smooth, fast application and easy wipe-off
• Restores a glistening “new paint” shine
#9
FEATURES:
• A deep gloss cleaner/polish
• Removes fine scratches and swirl marks, while
providing a dark, dramatic shine
• Formulated to reduce splatter & make application
and wipe-down easier
Just to note, they are both formulated for fresh paint.
I'm not saying you need to do a search on this question as our forum is not known to like a lot of other forums were every time you ask a question someone will tell you,
Do a search
However, this questions has been asked many times and a quick search using the terms
#9 and #82 sound like they do the same thing with the same aggresivness rating on the front of the bottle. What's the difference? I plan on using #9 on my truck but wondered what the difference is???
Adam
Hi all,
I am getting ready to order my first PC-100 Polisher and am putting togehter a list of products to order. I currently have #9 but wondered if there's much difference between #9 and #82?
Thanks for the help...
Tom
Good day fellow detailers. I have a simple question to ask, I think? I always wondered what the difference was between #9 and #82 polishes. They both have the same cutting ability of 3, and they both are polishes, so where do they differ? Does one offer more oils? What are your experiences with the two products and what do you
What's the difference between #9 #82 and #80 (http://meguiarsonline.com/forums/showthread.php?t=11647)
Hi amigos I am kind of lost and confuse now, yesterday I detailed a BMW, it was all repainted black, so i decided to sand it with 1500 grit because it had lot of orange peel. I cut half of the car with #85 and the other
Here's a start...
In a nutshell, M82 is a tad more aggressive than $9 but not enough that I think the average person could ever tell the difference. M82 is technology developed when we created the 80's serious line while M09 was introduced in about 1987 I think. It was one of, if not the only cross-over product at the time when basecoat/clear coat systems finally hit a critical mass in the collision shop industry and it was discovered that something more aggressive than a pure polish, (non-abrasive), yet less aggressive than a compound or paint cleaner was necessary to bridge the gap in order to create a swirl free finish in the re-finishing industry.
Basically if you're looking for a light cleaner/polish then either will fit the bill.
I find myself using either product when I'm working on very soft paints that are prone to micro-marring or as a last rotary applied product in a 3-step rotary process.
