Product Application Question
  • Product Application Question
    This will be my first attempt at the following on my new 2004 Black Jeep Liberty. All of this will be done by hand.
    1. Wash with Gold Class Car Wash Shampoo and Conditioner. Then dry.
    2. Deep Crystal Paint Cleaner.
    3. Deep Crystal Polish.
    4. 2 coats of NXT Tech Wax.
    My question is in each step for 2, 3, 4, should I cover the entire Jeep with the product then take it off or should I do one panel at a time? Any benefits covering the entire Jeep first?
    Any advice would be appreciated. Thanks.
    Jim
    I have never used the Deep Crystal system before so I am not sure about those but with the NXT you shoul dapply to the whole vehicle first. NXT needs about 15 or 20 minutes to cure before removing so you shoulld be able to do your entire Jeep in around that time.
      Thanks for reply. Anyone have any experience with the deep crystal system that possibly could give me some advice? Thanks.
      Jim
        With the NXT you can do the whole car and let it set-up for about 30 min and then buff it off. The cleaner and polish you should do by sections for best results. I use the cleaner section by section till the whole car is done, then i go back and do the polish the same way. After the car is cleaned and polished apply the NXT. I have never had a problem doing it this way. Good luck.
          I found it best to do a panel at a time and wipe off with both Deep Crystal 1 and 2.
            I have found that as well... don't let #2 dry as it gets hard to remove. #1 easy to apply and remove. Below in my signature the photos of my truck are:
            1. Deep Crystal Cleaner
            2. Deep Crystal Polish
            3. Nxt (2 coat method)
            I think the deep crystal systems works well great inexpensive product.
            Brandon
            2007 Black Chevy Avalanche
            My Albums: Avalanche
