I have a question regarding removing residue from pits in the paint. I've polished about 10 cars now using the PC along with Megs 80 speed glaze. How do I quickly remove the residue once the car is complete. Some of the cars have hundreds of small pits all over. Thanks for your help.
Clean Polish out of Pits
Re: Clean Polish out of Pits
What have you been using to wipe off the M80 Speed Glaze?
I remove the product entirely with a clean microfiber cloth as each section is complete. The residue is the same as what you find once the tape has been removed (white, pasty residue). The polish is settling into the pits where the microfiber is unable to remove it. Now granted, when I do remove the polish it, the car, looks clean until a day or so later. The only other thing it could be is wax but I doubt that. I've waxed many cars and have not this much problem. I believe the DA is driving the polish into the pits (rock chips) and showing up once the car gets out in the sun. On another board I was told to work some 50/50 water & rubbing alcohol into the areas (pits) that may turn white.
I've got a dark green 1999 Miata with similar small chips on the hood. You can't see them for the most part, but once a product gets into them and dries it does leave these little white spots. I don't believe it to be a question of improper technique with any product or tool, you just can't avoid getting product into these tiny little pits, and the pits are so small a simple wipe with a microfiber just can't get into them.
About the only thing I've been able to do is a little shot of a quick detailer followed with a touch of a detail brush, then wipe with a MF towel. It's tedious to say the least, but it gets rid of the little white dots. Well, most of 'em anyway.Michael Stoops
What about a hit with the pressure washer? maybe before the product sits there and dries to hard. I know it would likely remove some of the oils we all like from #80 but maybe in these special circumstances that would help. A hand applied coat of #7 or #81 could then be applied.
Again. Just throwing out ideas here. I have not run accross this problem before but I am sure I will.Jeff Smith
Originally posted by Jeff Smith
I know this will likely be seen as a no-no here but figured I would throw it out.
Again. Just throwing out ideas here. I have not run accross this problem before but I am sure I will.Michael Stoops
edit: but be sure to do it quickly after you're done buffing to make it easier to remove
