swirls swirls swirls
  • swirls swirls swirls
    I've just bought meguiars 3-step products today: the cleaner, polish and carnuaba wax (red busses).
    After detailing, I washed the car and again, I had a lot of swirls on my car.
    I've also ordered product n° 21 for protection. Will this help avoiding the swirls? Is it right that you have to use n° 21 after you used the 3 steps?
    What kind of shampoo of meguiars can I use the best to keep the dark, deep shine?
    Can I also use other shampoos with wax in it?
    Greets, bert
    Are you applying everything by hand?
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
      I ve applied the products by hand and afterwards I've spread it with the polishing machine at low RPM. I had even moistened the polish pad a little bit. After the polishing and after applying the carnuaba wax, i always use the microfibre cloths.
        You might have better results by using ScratchX by hand... I have used and really like the Deep Crystal System but for swirl remover IMO its not the best option.
        You speak of a polishing machine is it a....
        Rotary:
        PC:
        or something like this:
        As for #21 I have only used a little bit of it but there are lots of good posts on it. Seems everyone that uses it really likes how it performs.
        For Shampoos either: NXT Generation Car Wash or Gold Class Car Wash Shampoo & Conditioner work great! I prefer the Gold Class over NXT but either will work very well.
        Brandon
          I' am using the rotary machine.
          How do you apply your product to the paint?
          First apply by hand and afterwards spread it with the machine?
          OR
          applying the product to the pad of the machine and then spread it with the machine on low RPM?
          greets, bert
            OR
            greets, bert
            Ok, now that we have narrowed it down to the machine... I am not all that familiar with a rotary, someone else will have to chime in and guide you a little better than I can with products/processes, I have only used a rotary a hand full of times. I apply all my products with a PC.
            Now the I don't believe the Deep Crystal System is formulated to be used with a rotary it is formulated to be used by hand or PC, not sure but that may cause a problem. I do know you want to apply the product with the Rotary, working it in allowing the product to work in and do the job, then remove with a quality cotton towel or microfiber.
            Brandon
              thank you for the info.
              I think I'm now applying it by hand.
              What kind of product can I us with the rotary machine?
              Kind regards Bert
                The 3-step system is very good, but it will only remove very light swirls.
                I don't know what is available for you in Belgium, but you will need something from the Professional Product line to correct the paint defects.
                Don
                12/27/2015
                "Darth Camaro"
                2013 Camaro ... triple black
                323 hp V6, 6 speed manual
                  I think i'm going use this product maybe:
                  I can order it in a local car shop here.
                  Hope that's it be good?
                  maybe better products?
                  Greetz Bert
                    That is a good product, it's very mild, so you may have to apply it more than once.
                    Don
                    12/27/2015
                    "Darth Camaro"
                      You might be putting the swirls into your car's paint with the rotary. It is important that you use the right products with the right technique in order to get rid of swirls.
                      Tell us what products you used with a rotary. For example, waxing with a rotary buffer is not recommended.
                      Proud owner of the finest looking car in the parking lot.
                      Switch to Linux. Use energy efficient lightbulbs and appliances. Keep your car well maintained and drive easy to save gas. Eat less fast food. Call your mother and tell her you love her. Try flying a kite. Read a wikipedia article daily. Use Meguiar's.
                        a have applyed all the products with the machine, the rotary.
                        First by hand, and than spread out with machine.
                        I'm going really crazy form the swirls....
                        What are than the best steps to polish my indigo blue car?
                        I've also somthing like this, but I thougt that this was not so good...
                        What steps I'll take for best result?
                        Greets Bert
                          Ok, I dont really know what steps you can take with that machine, but I know what you can do using your hands.
                          Removing Swirls With Scratch-X
                            Are the swirls worse than before you started the detail?
                            Brandon
                              I always used riwax a suiss product and for protection autoglymm.
                              I've never had swirls,maybe some little but in the sun can't see swirls.
                              Now if the car is outside he looks ok, but don't put it in the garage, everywhere swirls.
                              this pictures let it see:
                              Before
                              is this just normal under that kind of light?
                              Greetz Bert
