Okay with all the experts we have out there can we get a step by step how to? I have a 2000 red neon i want to get rid of the swirl marks as many others do also! now i will be gettin the pc deal when it goes up for sale. so i will have a pc soon. what are the steps to get rid of the swirls? clay,polish,wax? THANKS!
Step by Step swirl mark HELP!
Re: Step by Step swirl mark HELP!
Any of Meguiar's cleaners will help remove swirl marks, but some are stronger than others.
I would recommend #83 DACP or MPPC...These two products are the strongest cleaners you can use with a PC, but I like the gloss #83 leaves behind...Use the W-8006 polishing pad with these products.
#82 SFP is a good follow up to the cleaners, as it will remove fine scratches and leave an incredible gloss behind....Use with W-8006 pad.
You can then finnish up with the NXT/W-9006 combo.
As for claying, I like the Quick Clay System.
Be sure to use a quality car wash, such as Gold Class with a wash mitt, and the 2 bucket wash method.r. b.
Looks like a winning formula for success. Speed on 5 for the PC should be fine. It would be best to wait 12-24 hours aftern the initial coat of Ntx before coat two is applied. Wax, either carnuba or polymer needs this amount of time to "cure".
Also, applying about 5 lbs of pressure on the PC is best for the results you are looking for regarding the application of the #83 and #82 products. You are working these in and breaking down the product. 6 lbs. looks and feels tight when the back plate presses into the pad enough so the PC reamins fliud and not stressed or dragging. It is a "feel" thing, also the sound wil assist you regarding pushing to hard. you will "hear' the strain."Automotive Detailing with a Passion!"
What do you guys think of this for the ultimate shine:
wash car
clay car
#83 with W-8006 pad
#82 with W-8006 pad
#81 with W-9006 pad
2 coats NXT wax W-9006 pad
Tom
98 MarkVIII LSC98 MarkVIII LSC
04 Honda Pilot
00 Harley Softail
"Son, you're gonna drive me to drinkin' if you don't stop drivin' that Hot Rod Lincoln."
Charlie Ryan - 1955
Yeah that's what I do for the ultimate shine
I have done it a couple of times now with great results.
I think for an interim detail with the paint in otherwise good order just doing #82 with the W8006 pad, followed by 2 coats of NXT with the W9006 pad is almost as good. You just seem to lack a bit of the depth you get with adding in the #81 on darker colours.
Then after each time you wash just give a quick coat of NXT Spray Booster Wax to keep it looking good.
clean car
clay car
#83 with W-8006 pad
#82 with W-8006 pad
2 coats NXT wax W-8006 pad
clean car
Is that the best way? i dont want anything to hard to do or work with. also whats speeds for each? Thanks alotr. b.
