| Myths & Confusion Articles to help clear up misinformation floating around in Cyberspace |
#11 | |||
Re: The good and the bad types of silicone.
Quote:
![]() It's easy to simply pass along bad information and often times on other forums there's no leading authority to question bad information so it goes unchallenged and because it goes unchallenged a certain percentage of people figure it must be correct because no one challenged it. Also, most other detailing discussion forums whether they are a dedicated detailing discussion forum or a segment of a theme-based discussion forum, (for example Corvetteforum.com is a theme-based discussion forum but they have a sub-forum for questions on detailing), it's a free-for-all environment which is a good thing, we offer a free-for-all environment but were also a HUGE supplier of non-silicone products as we've been making non-silicone products longer than most people posting to discussion forums have been alive. As a manufacture of products for both fresh paint and cured paint we have expertise for ALL segments of the market while most of the products you read about on detailing discussion forums are made by companies that only cater to the OTC market, that is the retail market, (both online and traditional), and that means the only make products for "cured" paint" for example the paint on a new car while we make products that can be used on paint as soon as it's tack-free, fresh out of the paint booth. Huge difference in product offering and the expertise that goes with it. ![]() Quote:
If Meguiar's chemist include ANY ingredient in ANY formula/product, it's for one of two reasons and usually both...
An example of #1 would be an abrasive is a key ingredient in a product intended to be used to remove below surface defects, therefore an abrasive in a compound is a benefit to the process. An example of #2 would be be a silicone can be used to make a product easier to spread out and wipe off, that's a benefit to the user. There are all kinds of silicones and most of the fear mongering over this single ingredient is by people that don't understand that body shops understand that before painting any car... they need to properly prepare the paint and that would include removing anything from the surface that could interfere with surface adhesion before the paint is sprayed. Here's the text a question from our FAQ that addresses this topic in detail... Quote:
As discussion forums continue to evolve, the important factor that will insure you can take the information you get from one is whether or not it helps you to be successful when you work on your car in the garage. And if something goes wrong... someone to come back to that's held accountable for the information on the forum. We take great pride in that the how-to information and the products that accompany this how-to information on this forum have a history of helping our members and yes our 'lurkers' of dong just that. We encourage everyone to post their questions to as many forums as they deem worthy and then everyone can decide for themselves who to trust. The Internet in general and discussion forums in specific are the ultimate equalizers because you the customer can talk back.... (unless your a lurker) ![]()
__________________
#12 |
Administrator
I entered into a little discussion on another car forum about both silicones and petroleum distillates, and the amount of disinformation and gross lack of knowledge was astounding. One poster went so far as to say he only uses brand "X" because their interior vinyl and rubber protectant contained no silicones or petroleum distillates at all - he would never let those ingredients anywhere near his car because they are the worst thing one could possibly use on those surfaces. Swore up and down that 5 years of regular use with brand "X" and he never had a problem.
In this case brand "X" is a highly respected boutique product and I thought his choice in product was a very reasonable one. But I highly doubted his claim that it was silicone and petroleum distillate free - so I requested an MSDS sheet for the product. Yep, it's loaded with silicone. Not a bad thing obviously as that one particular poster has been using the stuff regularly for 5 years without a hint of trouble. But he was terribly misinformed not only about silicones in general but about the very same "high end" product he was using. Like Mike Phillips said, it's easy to pass along bad information.
__________________
Michael Stoops Internet Technical Specialist Meguiar's Inc. (800) 854-8073 xt 175 mstoops@meguiars.com |
#13 |
It's funny when someone says,
"I won't use a product with petroleum distillates on my car's paint" Modern car paints include petroleum distillates, in fact some of the base ingredients that make up the actual resin are either derived from petroleum crude oil or liquid petroleum gas, (LPG), thus what they're saying is... "I won't use petroleum distillates on my petroleum distillate" Kind of funny... And of course there's always this example of how dangerous petroleum distillates can be... Chap-Stick, a product you apply to your lips contains 44% Petrolatums See these threads also on petroleum distillates... http://meguiarsonline.com/forums/showthread.php?t=171 http://meguiarsonline.com/forums/showthread.php?t=11116 http://meguiarsonline.com/forums/showthread.php?t=19470 http://meguiarsonline.com/forums/showthread.php?t=19664 http://meguiarsonline.com/forums/showthread.php?t=26020 And here's an article on silcones... The Role Silicone Plays in Car Care Products At some point... you just have to put your trust in the name on the bottle... our bottle or some other companies bottle... Who you going to trust?
__________________
#14 |
i had a bad experience with meguiars leather cleaner and conditioner. i applied it to a mercedez black leather interior and it seemed that the silicone in it hazed the leather, luckily i only did one seat and quickly removed it with apc and hot water.
#15 |
Great write up mike. so....i trust that all the silicone products meguiars makes for my tires are safe and won't dry them out? Also, in my search for the right tire dressing I have found that most of them I have tried do leave a brown color on the tire that is very difficult to clean off. what causes that?
ps will be buying meguiars hyper dressing soon! |
#16 | |
Automotive Reconditioning Specialist
Quote:
__________________
We are all apprentices in a craft where no one ever becomes a master. Ernest Hemingway (1899-1961) |
#17 | |
Quote:
Will some tire cleaner/foams/dressings dry rot your tires?
__________________
#18 | |
Director of Training
Quote:
To blame "silicone" is a pretty powerful statement, see all above posts A better way to for all to receive your post is....you had undesirable results with one of our leather products, so you removed it and corrected it with apc & hot water. We know there are times when a product may not work as expected, and we also know we will not satisfy everyone all the time, but our goal on MOL is to make sure good information is spread. Mike
__________________
Mike Pennington Director of Training and Consumer Relations Meguiar's, Inc. mpennington@meguiars.com |
#19 | |
Quote:
In the tire industry it is referred to as "blooming". Mike
__________________
#20 |
Administrator
"Blooming" seems to be more noticeable on some brands of tires than others and can also be effected by amount of exposure to harsh sun and/or amount of use. Recently with my own vehicles I had one with an extremely high degree of "blooming" or "browning" of the sidewalls. All the cars had different a different brand of tire: Michelin, Falken, BFGoodrich and Continental. All tires were cleaned the same way (APC diluted 10:1) and treated with the exact same tire dressing (Hot Shine Tire Coating). Only the Michelin tires exhibited the browning of the sidewalls - a dead giveaway that the tire dressing was not the cause.
__________________
| Rotary Good and Bad - Help | bindog | Detailing 101 | 14 | May 6th, 2008 06:10 AM |
| The good, the bad, the eBay | PorscheGuy997 | The Break Room | 38 | Feb 12th, 2008 10:12 AM |
| The good and the bad types of silicon. | Classiccars | Interior Care | 14 | Feb 26th, 2007 07:37 AM |
| #16 Over NXT..Good or Bad? | mcmmotorsports | Detailing 101 | 3 | Feb 23rd, 2006 12:56 AM |
