Follow us on: Follow Meguiars on Twitter
Customer Care Center:
800-347-5700
Go Back   Car Care Forums: Meguiar's Online > Detailing - Everything from A to Z > Tricks of the Trade!
Tricks of the Trade! Have a special tip or technique that you think might help others? Post it here!
Reply
Old Mar 24th, 2009, 02:03 PM   #1
PorscheGuy997
Person
PorscheGuy997's Avatar
Rep Power: 24 PorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud of
A look into Pad Priming - The Kevin Brown Method
Hey everyone,
I thought I would give you guys a little sample of Kevin's paper. One of the most important topics covered is pad priming. Although it may seem simple, I wanted to clear up some confusion.
When I refer to pad priming, I am referring to the liquid that will be used in polishing - not a spray detailer.
M105, M205, M86, D151, SwirlX, ScratchX 2.0, and Ultimate Compound use abrasives that are uniform and non-diminishing (SMAT). That means that they are very different than most products that use abrasives that break down. These products that use non-diminishing abrasives rely heavily on the lubricant. If there is too much lubricant, then the cut will be reduced because the abrasive is floating in lubricant. If there is too little lubricant, then the product will "flash" very quickly and you will need to reapply product.
The best way to utilize the products listed above (non-diminishing or SMAT) is to prime the pad. To do so, take the product and pour some on the pad. Then, rub it in. You are not trying to spread butter on toast! Aggressively rub the product into the pad until the entire surface is covered.
To show the method, I chose M205 and a W9207 finishing pad.
Below is an example of a poorly primed pad. As you can see, the product has completely filled in each of the pores. This will waste product and reduce the cut.
Here is what a properly primed pad should look like. The pores are not filled with product, but there is still product available in the pores.
To give you a better idea of what the pores look like, I took a macro shot of the above pad properly primed with M205.
Hope that helps!
__________________
Chris
Dasher Detailing Services
PorscheGuy997 is offline   Reply With Quote
Old Mar 24th, 2009, 03:37 PM   #2
dvtldav
dvtldav's Avatar
Rep Power: 9 dvtldav has a spectacular aura aboutdvtldav has a spectacular aura aboutdvtldav has a spectacular aura about
Re: A look into Pad Priming
Chris,
Try to remember to show us that on May 9th when we are down for the Midwest get together.
Dave
__________________
You repair things with tools. You fix things with a hammer.
dvtldav is offline   Reply With Quote
Old Mar 24th, 2009, 03:38 PM   #3
3Fitty
They call me fitty
3Fitty's Avatar
Rep Power: 21 3Fitty is a splendid one to behold3Fitty is a splendid one to behold3Fitty is a splendid one to behold3Fitty is a splendid one to behold3Fitty is a splendid one to behold3Fitty is a splendid one to behold3Fitty is a splendid one to behold
Thanks for the post Chris. Great information for anyone!
__________________
3Fitty is offline   Reply With Quote
Old Mar 24th, 2009, 04:49 PM   #4
BlueZero
Avatar Czar
BlueZero's Avatar
Rep Power: 37 BlueZero is a glorious beacon of lightBlueZero is a glorious beacon of lightBlueZero is a glorious beacon of lightBlueZero is a glorious beacon of lightBlueZero is a glorious beacon of light
Great info Chris! Thanks for posting it here!
What do you use to spread and rub the product in? First thought would be your hand but I'm wondering if there isn't a less messy option that works as well.
__________________
Scott
BlueZero is offline   Reply With Quote
Old Mar 24th, 2009, 05:04 PM   #5
Carfire
Fire Dept. Detailer
Carfire's Avatar
Rep Power: 32 Carfire is just really niceCarfire is just really niceCarfire is just really niceCarfire is just really nice
Great Pictures!!
Thanks for the Tips!!
__________________
'02 Town and Country
Carfire is offline   Reply With Quote
Old Mar 24th, 2009, 05:10 PM   #6
TimG
Learning True Art of Detailing
TimG's Avatar
Rep Power: 36 TimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond repute
Reminds me of Oreo's biscuits. Lol
Thanks for the share dude!
__________________
TimG is offline   Reply With Quote
Old Mar 24th, 2009, 05:33 PM   #7
Nick Chapman
Formerly "n737nc"
Nick Chapman's Avatar
Rep Power: 294 Nick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond repute
This really does work guys. Been doing it this way for a while now(ever since Lord Brown showed me ).
__________________
2008 Meguiar's Batmobile Team
2008 Meguiar's/Ford SEMA Team
2009 Meguiar's/Ford SEMA Team
Nick Chapman is offline   Reply With Quote
Old Mar 25th, 2009, 04:26 AM   #8
3Fitty
They call me fitty
3Fitty's Avatar
Gents,
I would imagine you would try to work it in the same way with the CCS foam pads?
Even in the little divets?
__________________
Old Mar 25th, 2009, 06:10 AM   #9
J. A. Michaels
aka: 23jam
J. A. Michaels's Avatar
Rep Power: 509 J. A. Michaels has a reputation beyond reputeJ. A. Michaels has a reputation beyond reputeJ. A. Michaels has a reputation beyond reputeJ. A. Michaels has a reputation beyond reputeJ. A. Michaels has a reputation beyond reputeJ. A. Michaels has a reputation beyond reputeJ. A. Michaels has a reputation beyond reputeJ. A. Michaels has a reputation beyond reputeJ. A. Michaels has a reputation beyond reputeJ. A. Michaels has a reputation beyond reputeJ. A. Michaels has a reputation beyond repute
Chris,
Thanks for taking the time to do this. I know it will help myself and others. Thanks again.
__________________
J. A. Michaels is offline   Reply With Quote
Old Mar 25th, 2009, 02:56 PM   #10
PorscheGuy997
Person
Quote:
Originally Posted by 3Fitty View Post
Gents,
I would imagine you would try to work it in the same way with the CCS foam pads? Even in the little divets?
There really shouldn't be any problem with priming a CCS pad. It will be a little more difficult to do, but I can't see anything going wrong.
__________________
Chris
Reply
Tags
Kevin Brown Method
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Priming a Pad sudsbyhubbs Detailing 101 10 Nov 25th, 2008 01:49 PM
Priming a new/dry foam pad. premier.mobile1 Detailing 101 6 May 28th, 2008 11:42 AM
Priming New/Clean Pad zey Detailing 101 8 Jul 18th, 2005 04:08 PM
Priming pad for NXT w/Booster? Don Consumer Line 10 Oct 5th, 2004 11:51 AM
Priming Foam Pads screemingtp Professional Line 0 Mar 11th, 2004 09:45 AM
©2004 - 2009 Meguiar's Inc.
