Priming a Pad
I found this advice on autopia by Kevin Brown and I'm curious about where he mentions priming the pad. Does he mean priming it with something like Final Inspection or is he talking about actually priming it with the product?
In a nutshell, a good procedure when using M105 with a foam pad for mild or final-polishing (rotary applied):
1. Prime the pad THOROUGHLY.
Rub it in with your hand. It'll take a bit more than you're used to applying. It takes quite a bit to load (more than a typical polish, as there's no petro-based oils or solvents to aid in spreading).
Take the extra time to completely cover the face and outer curved-edge of the pad. .
2. Apply a bead of M105 to the surface, pull it in, and polish at low speed (1000 rpm).
USING CONSISTENT MODERATE DOWNWARD PRESSURE, apply for 1-3 passes, or until the M105 is just starting to dry. Remove all residue. CHECK FOR HEATING OF THE PAINT. Most guys that polish with a rotary know how HOT the surface can get when using a finishing pad.
