Go Back   Car Care Forums: Meguiar's Online > Meguiar's Online Showcase > Show Off Your Latest Detail Work
Show Off Your Latest Detail Work "It ain't braggin' if you can back it up." "Dizzy Dean"
Reply
Old Aug 4th, 2008, 01:42 AM   #1
Kevin Brown
Kevin Brown's Avatar
Rep Power: 443 Kevin Brown has a reputation beyond reputeKevin Brown has a reputation beyond reputeKevin Brown has a reputation beyond reputeKevin Brown has a reputation beyond reputeKevin Brown has a reputation beyond reputeKevin Brown has a reputation beyond reputeKevin Brown has a reputation beyond reputeKevin Brown has a reputation beyond reputeKevin Brown has a reputation beyond reputeKevin Brown has a reputation beyond reputeKevin Brown has a reputation beyond repute
Work Truck Detail 65+ pics...!
We all like to read about detailing, especially when it’s done to exotic cars.
Reality is, most of us work on common vehicles, and I am no exception.
Although I do get to work on some really trick rides, I’ve washed & detailed thousands of daily drivers.
Recently, I spent some time detailing a Toyota Tundra.
It had logged 77k miles in about 1-1/2 years, and was used as a work truck.
The owner decided to have it cleaned up, as it was no longer going to be used in the field.
A friend of mine asked if I could do the truck.
The owner of the truck has given my friend lots of work, so it was important that the job be done right.
Here’s some pics of the detail. I did not plan on doing a write-up... I took pictures for my own reference.
Consequently, I didn’t get all the shots I should have (such as a finalized engine!). I think you’ll get the idea, though...
__________________
Kevin Brown
Kevin Brown is offline   Reply With Quote
Old Aug 4th, 2008, 01:46 AM   #2
Kevin Brown
Re: Work Truck Detail 65+ pics...!
The truck was used off-road quite a bit. Dirt and tar are plentiful.
More dirt PLUS a lot of bugs litter the radiator area.
The engine looks as if it’s ten years old.
The wheels are hammered, and feature bush & dirt scratches, with a dose of tar.
Hood area matches the rest of the truck: Dirty.
Making our way to the interior, more of the same.
Doorjambs, carpet and the rest will need thorough cleaning.
Removal of the kickpanels reveal electronics I don’t want to get wet!
Door panels were removed to properly clean the backsides, speakers, & grills.
Window rubbers and felts are much easier to access this way, too.
Shot of the door panel.
__________________
Kevin Brown
Old Aug 4th, 2008, 01:50 AM   #3
Kevin Brown
Gauges are dirty and the plastic fascia very scratched.
Under the dash reveals a grimy a/c area and airbag.
A pile of easy to remove parts that will be thoroughly cleaned and reinstalled.
Air vents are pretty loaded with dirt and old interior dressing.
Driver’s seat removed.
The center console and carpet were much easier to clean, too.
See? Incredibly, the carpet was not too bad in the rest of the truck.
Exterior- Needs a lot of attention.
M105 applied by hand will tackle the areas which cannot be machine polished.
__________________
Kevin Brown
Old Aug 4th, 2008, 01:54 AM   #4
Kevin Brown
There were MANY scratches- Some required 2500 grit sanding.
Some scratches were very deep. This one was only partly removed.
It was hard to locate it once the polishing was done, as the scratch-edges were smoothed..
Lots of heavy scuffs that were completely removed via M105.
A test spot helps dial-in the polishing system. M105. Okay, that was easy.
This scratch was deep. It really stood out, so I had to sand it with 2500.
Gonna have to leave it like this and polish to an acceptable finish.
__________________
Kevin Brown
Old Aug 4th, 2008, 01:57 AM   #5
TimG
Learning True Art of Detailing
TimG's Avatar
Rep Power: 33 TimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond repute
looks like an extreme makeover...cant wait to see more pixxies
Tim
__________________
TimG is offline   Reply With Quote
Old Aug 4th, 2008, 01:58 AM   #6
Kevin Brown
Meguiar’s Detailer D103 All Purpose Cleaner Plus was used throughout the interior.
No extractor, here... Just APC+, water, brushes, and a Craftsman wet/dry vac.
Towels and a warm summer day handle the drying duties.
Carpets are rinsed until dirt & APC+ is removed.
Door sills are cleaned easily.
Meguiar’s M40 Vinyl/Rubber Cleaner & Conditioner applied for beauty & protection.
Small parts are easily cleaned. Electronic buttons, such as this were cleaned sans water.
A dry towel & horsehair brush to clean. G134 Exterior Trim Coating to dress.
No water, so it’s safer to use around electronics (versus traditional dressings).
My helper, Annie, is not much help.
Under dash components are cleaned (to a degree). Not perfect, but pretty good.
Vents cleaned with APC+, agitated, and a pressure washer rinse.
Once dried, Exterior Trim Coating adds sheen without stickiness.
Results of APC+, thorough cleaning & vaccuuming, & M40.
Rest assured, carpet is super-clean.
Glove box hinges & latches are free of sticky dressing & gritty dirt.
Water-spots & dust particultate handled upon final wipedown.
Plastic gauge fascia polished via M105 & Meguiar’s Ultimate Wipe.
All other dash areas cleaned with APC+. M40 & G135 protect & beautify.
__________________
Kevin Brown
Old Aug 4th, 2008, 02:05 AM   #7
Kevin Brown
Pressure washer, towels, & vacuum super-sanitize center console.
Not shown- Two other cubby areas & cupholders built into console. They looked good.
Headliner cleaned up nicely with APC+ and a bit of lacquer thinner.
Seatbelts cleaned with APC+, a green Scotchbrite, and a pressure washer.
Fully extend seatbelts to outside of cab, shut door, clean.
Areas that cannot be pulled outside of cab surround with towels and vacuum excess water.
Wipe aggressively with towels, and leave fully extended to air-dry.
Under-seat areas were dialed in by hand. Yellow wiring means airbag!
Doorjambs cleaned just like the engine bay.
Rinse with deionized water, mist on APC+, & agitate with a brush & sponge.
Then, use Meguiar’s Detailer D130 Body Solvent to remove stuck-on tar & dirt-embedded grease.
These particular jambs had a lot of calcium deposits (as did the emblems).
An application of Meguiar’s Detailer D32 Wire Wheel Cleaner handled the situation.
Mist, agitate, & rinse. A soapy-water rinse negates acid remnants.
Meguiar’s Detailer D140 Wheel Brightener cleans the wheels.
Meguiar’s Detailer D130 Body Solvent removes tar speckles.
Meguiar’s M105 Ultra Cut Compound used to polish wheels.
I was able to use my Metabo SXE400 random-orbital with 3” foam pads to apply.
Once all four wheels were cleaned I moved the truck a bit to access the areas that I couldn't reach...
Due to the brake-caliper size... After this shot.
Meguiar’s Detailer D108 Super Degreaser cleans tires, fenderwells, & mudflaps.
Meguiar’s D170 Hyper Dressing diluted 50/50 with water used to dress tire tread & fenderwells.
Meguiar’s M40 Vinyl & Rubber Cleaner/Conditioner used to dress sidewalls & mudflaps.
Cowl area cleaned with APC+, than dressed with M40.
All exterior glass polished with M105, applied with Metabo & a 3” foam pad.
Residue removed with D112 Super Soap and water. Pressure washer rinse.
Windshield edges carefully scraped with a razor blade.
__________________
Kevin Brown
Old Aug 4th, 2008, 02:10 AM   #8
Kevin Brown
Underhood looks fresh again.
Grille cleaned with APC+, then acid, then soap, and finally dressed with M40.
Radiator support- Sorry, no pic of the radiator & complete support... DOH!
Undercarraige looks respectable again.
Tailpipe cleaned with APC+, acid, then a soap rinse.
Wish I’d seen the scratches on the tip- M105 would have removed them easily!
It’s these areas that really make a detail right- Time-consuming, but what a difference.
Emblems cleaned via APC+ & a toothbrush & vent brush.
After a soapy water rinse, acid is applied & agitated.
Water rinse again. After machine paint-polishing, M105 is applied by hand to and around
the emblem. Soapy water is applied via trigger bottle, agitated, & pressure washer rinsed.
This is the spot where that big scratch was- Look closely and you can still see it.
From most angles, and in most light situations, it’s hardly noticeable.
Pickup bedside looks nice.
__________________
Kevin Brown
Old Aug 4th, 2008, 02:14 AM   #9
Kevin Brown
Side shot.
Door handles look clean and feel smooth. M105 & Ultimate Wipes did the trick.
Looks like a different truck.
The owner was appreciative. My friend was pleased. I am happy it's done! Thanks for reading.
__________________
Kevin Brown
Old Aug 4th, 2008, 02:25 AM   #10
TimG
TimG's Avatar
Truly awesome work.
Thanks for the share. Really made my day better
Tim
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
2003 Charcoal Silverado work truck jmakado Show Off Your Latest Detail Work 7 Jul 10th, 2008 01:20 PM
Cleaned up the Cab of the work truck today RogueGypsy Interior Care 2 Apr 20th, 2008 03:54 AM
1986 F150 XL Work/Play Truck roushstage2 Show Off Your Latest Detail Work 4 Apr 30th, 2007 07:00 PM
Clean4U's Work Truck Justin Murphy Show Off Your Latest Detail Work 4 May 22nd, 2006 06:55 AM
My 2004 Chevy Work Truck BoilerPete Show Off Your Latest Detail Work 3 Sep 4th, 2005 05:46 PM
©2004 - 2009 Meguiar's Inc.
