Go Back   Car Care Forums: Meguiar's Online > Detailing - Everything from A to Z > Detailing 101
Detailing 101 New to detailing or just have a question? Ask here!
Reply
Old Jul 21st, 2008, 10:23 AM   #1
mckeand13
mckeand13's Avatar
Rep Power: 6 mckeand13 is on a distinguished road
Having trouble with #7
Just got done washing my '02 Accord which is a maroon/red metallic paint. Temp was about 75degF and overcast so the car was cool. I use cold water for wash/rinse as well so that also keeps everything cool. After washing I pulled it in the garage.
I've used #7 in the past and it really deepens the color which I like. I tried applying it this time and had a lot of trouble. I put a small bead on a foam applicator and started rubbing it around. It seemed as though it was drying very quickly and I have never had that happen before. In the past it seemed as though I was applying and removing something that stayed very oily.
As I rubbed it around, it would even start to ball up and come off of the finish.
I tried applying less as that always seems like the rule, but it got to the point where I was putting just a 1/4" dot on the pad for an area (2' x 2' at most) and I couldn't even get everything in my area covered.
I didn't think this product was even supposed to dry. It almost seemed like I was waxing the car. It was weird. It also left a dark colored residue on my microfiber as I wiped it off. All signs point to too much product, but I swear I was using very, very little of it.
Any suggestions? I has worked before. It has always been stored in my basement and never frozen. I have no idea how old it is.
Thanks.
__________________
It's only weird because it's not normal
www.project-one.us
mckeand13 is offline   Reply With Quote
Old Jul 21st, 2008, 10:26 AM   #2
Mike Phillips's Avatar
Rep Power: 544 Mike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond repute
Re: Having trouble with #7
Try using more product... apply a teaspoon to a tablespoon to your applicator pad and then use a circular motion to spread it out over the area you're working.
Apply, spread out, work in and then wipe off.
__________________
Mike Phillips is offline   Reply With Quote
Old Jul 21st, 2008, 11:13 AM   #3
Nick Chapman
Formerly "n737nc"
Nick Chapman's Avatar
Rep Power: 292 Nick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond reputeNick Chapman has a reputation beyond repute
....and work a smaller area
__________________
2008 Meguiar's Batmobile Team
2008 Meguiar's/Ford SEMA Team
2009 Meguiar's/Ford SEMA Team
Nick Chapman is offline   Reply With Quote
Old Jul 21st, 2008, 12:04 PM   #4
mckeand13
mckeand13's Avatar
Mike,
Maybe I'm reading this wrong, but more product seems to go against your comments in this post:
http://www.autopia.org/forum/detaili...-phillips.html
__________________
www.project-one.us
Old Jul 21st, 2008, 12:05 PM   #5
mckeand13
mckeand13's Avatar
Can #7 be applied with a G100 for larger panels? If so, I would assume the 9006 pad?
__________________
www.project-one.us
Old Jul 21st, 2008, 12:11 PM   #6
3Fitty
They call me fitty
3Fitty's Avatar
Rep Power: 20 3Fitty is a splendid one to behold3Fitty is a splendid one to behold3Fitty is a splendid one to behold3Fitty is a splendid one to behold3Fitty is a splendid one to behold3Fitty is a splendid one to behold3Fitty is a splendid one to behold
Use the 8006 pads for #7 and use the 9006 pads for your LSP.
__________________
3Fitty is offline   Reply With Quote
Old Jul 21st, 2008, 12:18 PM   #7
PorscheGuy997
Person
PorscheGuy997's Avatar
Rep Power: 23 PorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud ofPorscheGuy997 has much to be proud of
#7 doesn't have any cleaners, so it's not worthwhile to use a 8006 pad.
__________________
Chris
Dasher Detailing Services
812-893-1127
PorscheGuy997 is offline   Reply With Quote
Old Jul 21st, 2008, 12:23 PM   #8
jmakado
jmakado's Avatar
Rep Power: 8 jmakado is on a distinguished road
I have much better luck using #7 via the PC than by hand personally. I use the tan 9006 pad. I work VERY fast when using #7 and cover 1/2 panel at a time with about 4-5 pea sized drops on the pad.
__________________
Jason
jmakado is offline   Reply With Quote
Old Jul 21st, 2008, 12:31 PM   #9
3Fitty
They call me fitty
3Fitty's Avatar
I'm dyslexic.
__________________
Old Jul 21st, 2008, 12:44 PM   #10
Orca
Rep Power: 3 Orca will become famous soon enoughOrca will become famous soon enough
I work by hand and have had a lot of success with #7 working in areas little over 1'x1' (maybe up to 20"x20" at the extreme). I use a hand pad with a good squirt which might equate to about a teaspoon, as Mike says, and work is quickly over the area. DO NOT ALLOW IT TO DRY or it will ball up as you have found. Once spread, just go over it to break it up a little (you will feel it kind of creak) and then wipe off with microfibre. Have your microfibre quartered and handy already on the panel ready to bring into action. Buff ... apply your favourite LSP. That's the hand technique, anyway ... hopefully you'll get some good advice about using your machine. Not having had the experience, I couldn't comment.
Personally, I find this such a pleasurable product to work with by hand and quick, too, I think you guys with your machines are missing out. Certainly polish and correct with a machine and apply your LSP by machine, but this glaze does warrant some hand applied lovin' ... it's like massaging your car after giving it a good scrub
Orca is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
having trouble jader2012 Detailing 101 2 Apr 2nd, 2008 02:44 AM
Having trouble w/ Scratch-X kanabro Detailing 101 3 Jan 20th, 2007 11:54 PM
Some of my trouble spots Jonje Detailing 101 3 Jul 15th, 2005 11:19 AM
Trouble with #80 ptim Detailing 101 7 Apr 2nd, 2005 10:24 PM
Having trouble with #83 1badstang Professional Line 19 Jul 17th, 2004 10:56 PM
©2004 - 2009 Meguiar's Inc.
