Follow us on: Follow Meguiars on Twitter
Customer Care Center:
800-347-5700
Go Back   Car Care Forums: Meguiar's Online > Meguiar's Products > Consumer Line
Consumer Line NXT Generation, Gold Class, Deep Crystal, Hot Rims, Hot Shine, ScratchX, ColorX, PlastX and all other consumer line products.
Reply
Old Apr 2nd, 2008, 06:40 AM   #1
Jesstzn
Rep Power: 6 Jesstzn is on a distinguished road
Layering NXT or NXT 2.0
Can either of these be effectively layered. I know you can keep applying but is there enought cleaners / abrasives in NXT to remove the leayer of NXT below or a portion of it?
I'm not talking about the act of friction from application .. but the results of the chemicals/solvents/cleaners/ abrasives "IN" the product removing whats cured below.
__________________
P M S Adjuster
Jesstzn is offline   Reply With Quote
Old Apr 2nd, 2008, 06:57 AM   #2
Mike Phillips's Avatar
Rep Power: 550 Mike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond repute
Re: Layering NXT or NXT 2.0
Mike Pennington commented on this on the old CS forum...
http://forumarchive.meguiars.com/forums/post/49603.aspx
Remember, Meguiar's teaches that after 2, maybe 3 applications of any product you will have hit a plateau, that is more and more product doesn't equal more and more thickness of a layer of protection.
There's a thread on this in Hot Topics
What's the deal with "Layering?"
The Law of Diminishing Returns
(Thomas Malthus "Essay on the Principle of Population" published in 1798.)
While this theory is generally used to discuss topics as they relate to the areas of economics and politics, it is a model that can also be used to explain in this case, the complex action occurring at the microscopic level on the surface of your car's finish.
The law of diminishing returns as it relates to layering,
A surface, such as an automotive paint, can only hold so much product before all you're doing is removing all subsequent coatings applied to the surface.
That is to say, after the first, second and in some cases a third application/coating, any more product applied to the surface is merely removed when you wipe the excess off after waiting for the product to cure.
At this point you've reached a plateau (or limit), as to how much wax (natural or synthetic) a surface can hold. Once you reach this plateau, all further applications of wax simply become excess that will be removed (and thus wasted), during wipe-off because it has nowhere to attach and layer.
Of course, this all depends upon your definition of the word "Layer". If your definition of the word layer follows that of Webster's Dictionary:
2 a: One thickness, course, or fold, laid or lying over or under another.
Then yes, you can layer to a certain point. For example, you can add multiple layers of layerable waxes until the limit to how much a given surface of an automotive paint can hold before each additional application is simply removed, or replaces a previously applied layer.
You cannot layer to the point of developing a measurable film-build, and this is key; without negatively affecting, or diminishing to some degree, the shine, optical clarity, gloss, reflectivity, depth of color etc. of the finish
This is especially true if the product you're applying is not clear (in and of itself) to start with. If your definition of the word "layer" follows that of definition used by some on the Internet,
Layer 1: To continually build a greater level of protection with each additional application, or layer, of a wax or protectant. (Natural or synthetic)
Layer 2: To continually increase shine, optical clarity, gloss, reflectivity, depth of color without end and/or after a plateau, or point of maximum potential has been achieved.
Then no, you cannot layer a wax, synthetic, natural, or otherwise.
__________________
Mike Phillips is offline   Reply With Quote
Old Apr 2nd, 2008, 08:00 AM   #3
Jesstzn
Yes I have read that before but it doesn't answer the question asked.
__________________
P M S Adjuster
Old Apr 2nd, 2008, 10:39 AM   #4
CWM3
Rep Power: 6 CWM3 is on a distinguished road
NXT/NXT 2.0 (or the "pro" version #21) can be effectively applied with two coats. NXT cleaners are said to be so mild it will not remove the prior "layer" (I prefer the term application) of wax. Mike Pennington did mention it in the link that Mike Phillips offered.
Quote:
NXT Gen Tech Wax is not a cleaner/wax and will not remove M21 or M21 is not a cleaner/wax and will not remove NXT Gen Tech Wax if you try and layer the products
Also mentioned was that "layering" is more for uniform protection, not necessarily better protection. What Mike Phillips offered was that many people write that they apply (or layer) 3 coats of wax. That much paint rubbing is bound to be counter productive after awhile.
Look at it this way, even if you washed with plain, soft, filtered water and a super soft wash mitt, you will eventually remove product with enough rubbing. Same thing with wax.
Besides who needs three coats of wax when you can be anal (like myself) and wax every other week?
CWM3 is offline   Reply With Quote
Old Apr 2nd, 2008, 11:19 AM   #5
roushstage2
Local Roush Master
roushstage2's Avatar
Rep Power: 131 roushstage2 has a reputation beyond reputeroushstage2 has a reputation beyond reputeroushstage2 has a reputation beyond reputeroushstage2 has a reputation beyond reputeroushstage2 has a reputation beyond reputeroushstage2 has a reputation beyond reputeroushstage2 has a reputation beyond reputeroushstage2 has a reputation beyond reputeroushstage2 has a reputation beyond reputeroushstage2 has a reputation beyond reputeroushstage2 has a reputation beyond repute
Yes, they can be layered (multiple coats). NXT has some light cleaners in it, so it will remove a bit of the coat below it. A lot of people top NXT with a pure wax so as not to remove any wax.
__________________
Tyler C.
MOL Mustang Enthusiasts
roushstage2 is offline   Reply With Quote
Old Apr 2nd, 2008, 12:22 PM   #6
Larry A
Rep Power: 11 Larry A is on a distinguished road
If I clean the paint with Klasse AIO or Color X, will NXT 2 remove any or all of the coating that KAIO or Color X leaves behind.
Larry A is offline   Reply With Quote
Old Apr 2nd, 2008, 01:09 PM   #7
Jesstzn
Quote:
Quote
The question is .. Will NXT remove or partially remove the layer of NXY below it.
Also mentioned was that "layering" is more for uniform protection, not necessarily better protection. What Mike Phillips offered was that many people write that they apply (or layer) 3 coats of wax. That much paint rubbing is bound to be counter productive after awhile. Off topic
Look at it this way, even if you washed with plain, soft, filtered water and a super soft wash mitt, you will eventually remove product with enough rubbing. Same thing with wax. off topic
Poster below says it has cleaners and may remove some of the layers below.
__________________
P M S Adjuster
Old Apr 2nd, 2008, 02:53 PM   #8
roushstage2
Local Roush Master
Quote:
It won't completely remove the layers, but it does have a sleight amount of cleaners in it. This is to help it adhere to the paint better. You can apply multiple coats of it though.
__________________
Tyler C.
Old Apr 2nd, 2008, 03:21 PM   #9
CWM3
You can apply wax and then apply NXT 2.0 without issue. ANY wax, including NXT, can be applied "below" NXT.
Old Apr 2nd, 2008, 03:32 PM   #10
Jesstzn
Right ... so you will put a sealant over a carnuba? And it will bond?
__________________
P M S Adjuster
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
NXT 1.0, Quick Wheel Detailer, NXT Spray Wax Sandstone For Sale or Trade 0 Oct 27th, 2008 04:37 PM
GC or NXT (Its down to NXT Pst. and NXT Liq.) Thejoyofdriving Detailing 101 32 Mar 12th, 2007 05:01 PM
Question for Mequiar's - NXT Spray Wax vs. NXT Liquid Cassman Detailing 101 2 Aug 3rd, 2006 10:41 AM
Layering Gold Class or NXT? duckvett Detailing 101 3 Apr 15th, 2005 05:42 PM
layering NXT. supercharged Detailing 101 2 Aug 10th, 2004 09:44 AM
©2004 - 2009 Meguiar's Inc.
