| Detailing 101 New to detailing or just have a question? Ask here! |
#1 |
how would this work out if..........
if i used the cleaner wax for a base coat, and then use the nxt or the gold class liguid wax. how much more does the cleaner wax do for the paint.
#2 |
Re: how would this work out if..........
This is a popular and effective way to clean and wax your car's paint, use the cleaner/wax as your paint cleaner and leave some protection, add a second coat of NXT or something else for more wax protection.
Common and popular combination is, A12 followed by NXT ColorX followed by NXT While the below car is an old car it has a modern basecoat/clearcoat finish on it. All work was done by hand by yours truly. Here's what ColorX did by hand to a 1947 Plymouth Coupe, Before - Horrible Swirls throughout the finish ![]() First we removed the white paint overspray using Meguiar's Quik Clay System now replaced with Smooth Surface Clay Kit. ![]() Then applied one hand application of ColorX followed by one hand application of NXT Tech Wax Liquid ![]()
__________________
#3 |
Raymond
Wow Mike that is amazing. The swirls on my Mustang aren't nearly that bad, but I've tried using Scratch X to remove them only to no avail. Should I go pick up some Color X and try it? Any tips on what you used to apply, exactly how you applied it, how long you let it set/dry, and how you removed it... would be great. Thanks in advance, that's an amazing transformation for hand-applied products.
Also, would using a coat of polish in between the Color X and the wax yield an even better shine? ![]()
__________________
--2004 Ford Mustang V6 -- Full mod list and some pictures at my SouthFloridaStangs Vehicle Garage -- |
#4 |
ScratchX would be the stronger cleaner, so for swirls, that should be the way to go by hand.
As far as a polish in between, ehhh.... it could be done, but you would likely be removing some/most/all of the first coat of wax. Since Meguiars recomends two coats of wax, you would be doing this: 1. Wash 2. Clay 3. ColorX (clean-->polish-->wax) 4. Polish 5. Wax 6. Wax If you are going to do that, you may as well have just used a dedicated cleaner. Plus you can kind of see how you are repeating yourself. At least in my opinion, if you arent going to be cutting out steps/saving time, there is no need for a cleaner/wax.
__________________
'08 Subaru Legacy 2.5i SE - Newport Blue Pearl |
#5 |
aka: 23jam
You would be creating a extra step in your process. I would go cleaner/wax then the nxt. Good luck.
__________________
quality creates its own demand |
#6 |
Maybe you should read this
The Definitive ScratchX Thread Collection
__________________
Francis Marranzini |
| How do they work? | Dieseljoe | Detailing 101 | 5 | Nov 20th, 2006 04:10 PM |
| Will #80 work for me? | Jeepster04 | Detailing 101 | 7 | Sep 27th, 2006 05:21 PM |
| Would this work... | 96Lude | Detailing 101 | 3 | Jun 28th, 2006 09:56 AM |
| will this work? | cliffor123 | Detailing 101 | 1 | Jun 28th, 2006 02:27 AM |
| How to work #9 | NVCobra | Professional Line | 11 | Oct 11th, 2004 04:50 PM |
