Go Back   Car Care Forums: Meguiar's Online > Information Station > How-To Articles
How-To Articles Please don't start a new threads in this forum. If you have a question, post it in Detailing 101 - Thank you!
Reply
Old Jun 22nd, 2004, 12:36 PM   #1
Mike Phillips's Avatar
Rep Power: 544 Mike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond reputeMike Phillips has a reputation beyond repute
How to use ScratchX by hand to remove swirls, scratches and water spot etchings
How to use ScratchX by hand to remove defects like these,
  1. Scratches
  2. Swirls
  3. Bird Dropping Etchings
  4. Water spots
  5. Scuff and Mars
++ = Success!
A couple of important notes to consider,
1) Clear coats are harder than traditional paints. This means they are more difficult to remove defects out of, especially by hand. This is part explains the increase in popularity of the Porter Cable Dual Action Polisher.
2) ScratchX is not a wipe-on, wipe-off product, (WOWO), it's more of a wipe-on, work-in product, (WOWI). You need to apply with a clean foam applicator pad and when you're applying it you need to put a little passion behind your pad.
Here is how to remove a bird dropping etching or an isolated scratch.
  1. Only work a small area at a time - about 6 inch by 6 inch area or smaller
  2. You can apply using a combination of circular motions and straight-line motions
  3. Work the product against the finish until it looks as you have almost run out of product.
  4. Re-apply the product and repeat the above steps 2-3 more times
When I apply ScratchX like I have listed above, I am able to get out about 95% of a bird dropping etching or isolated random scratches.
The trick is to work the product in until it just begins to disappear and to apply more than one application. You see, the ScratchX, like all Meguiar's Paint Cleaners, contain a diminishing abrasive, as you work ScratchX in, the microscopic diminishing abrasives gently abrade the surface removing small particles of paint. But as you work it in, these diminishing abrasives breakdown. Thus, they quit abrading the finish and actually polish the finish to a clear, high gloss. This diminishing action turned polishing action is a benefit to you because it enable you to work out defects without leaving scratches behind.
Because the diminishing abrasive breakdown, you need to re-apply and repeat the process until the defects are removed.
Note: You can rarely remove a bird dropping etching, or a scratch, from a clear-coated finish with one application.
"A little technique goes a long way"
ScratchX works, if you work it. It takes a little practice to get the hang of removing defects out of modern clear coats with hi-tech products like ScratchX. It' not like the old days with a traditional lacquer or enamel paint job where you could apply some old-fashioned rubbing compound and in a few passes, the scratch would be gone, (and so would a lot of your paint).
High gloss clear coats are thin delicate surface coatings that are easily dulled and easily scratched. Once they are dulled down and/or scratched, it takes the right product, the right technique together with the human element of care and passion to massage them back to a glistening gemstone.
Have patience, and if at first you don't succeed, try try again.
__________________
Mike Phillips is offline   Reply With Quote
Old Sep 16th, 2004, 09:08 PM   #2
How to remove the etching left by a bird dropping with ScratchX
At the recent San Diego Viper Detailing Clinic here at Meguiar's in Irvine, one of the club members showed me where a bird left him a little present on the hood of his black Viper. Below is a picture of the car after the Meguiar's polishing system...
Before ScratchX
After ScratchX
Note: The above after picture was taken after three applications of ScratchX that were thoroughly worked into the finish. Each application removed a little more paint and thus removed a little more of the etching. After three applications the etching was no longer visible from a couple feet away. We stopped here because we were going to machine polish the entire finish using the G-100a .
At the time the above after picture was taken, neither any polish or wax had been applied. The results will only get better with an application of a pure polish and then a couple of coats of wax.
Below is a picture of the same defect after a thorough polishing and waxing procedure was performed by the owner using the following products. (Note: The below is a list of all the products used over the entire car including the etching left by the bird dropping.
Products Used
Quik Clay System
G-100a
W-8006 foam polishing pad
W-9006 foam finishing pad
#83 Dual Action Cleaner Polish
#80 Speed Glaze
Meguiar's NXT Generation Tech Wax
Ultimate Wipe
Ultimate Bonnet
After
The 6.3 mega pixel camera, held about one foot away was able to capture what remains of the etching. The above photos are what are referred to as RAW format photos. That is they have not been altered or modified in any way, including resizing. They have been cropped out of the original at 700 pixels wide.
The after picture shows just a small amount of pitting, but not enough to continue removing clear coat from the finish because with your eyes up close, about one foot away, you cannot see this pitting. Standing directly over the hood of the car and looking directly into the hood, you can see no sign of the original etching.
When were were all through, the defect was no longer visible unless you knew where to look, were in the right light, and put your face right down close to the finish.
Read the entire detailing makeover on this Viper by clicking here...
__________________
Old Oct 25th, 2006, 08:10 AM   #3
calircr
Rep Power: 4 calircr is on a distinguished road
Re: How to remove a defect by hand with ScratchX
The reason I was asking about Scratch X is because I do have a lot of light cobwebbing swirls in my car...using Scratch X by hand over the whole car can be a bit time consuming.
When using the #80, so I apply to the DAP and spread it across until it becomes clear then wipe off with a microfiber towel? Or is it like wax, wait til it dries and then wipe off?
calircr is offline   Reply With Quote
Old Oct 25th, 2006, 02:53 PM   #4
gb387
gb387's Avatar
Rep Power: 67 gb387 is a splendid one to beholdgb387 is a splendid one to beholdgb387 is a splendid one to beholdgb387 is a splendid one to beholdgb387 is a splendid one to beholdgb387 is a splendid one to beholdgb387 is a splendid one to behold
There is no need to let #80 dry, remove it damp. Here is a link that might help with #80: How to use the G-100 to remove swirls
__________________
Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
gb387 is offline   Reply With Quote
Old Jan 14th, 2008, 04:55 PM   #5
Phostenix
Rep Power: 3 Phostenix is on a distinguished road
Do you need to wipe off the "used" ScratchX between steps 3 & 4, or just keep adding more?
Phostenix is offline   Reply With Quote
Old Jan 14th, 2008, 05:04 PM   #6
Quote:
Originally Posted by Phostenix View Post
[/list]Do you need to wipe off the "used" ScratchX between steps 3 & 4, or just keep adding more?
Remove any reside before adding fresh product.
IF you add fresh product to used product you dilute the fresh product, plus you might have loosened contaminants and particles of paint in the mix after a previous application.
__________________
Old Jun 2nd, 2008, 11:26 AM   #7
adriankeith
Rep Power: 2 adriankeith is on a distinguished road
Saw a live demonstration by Mike and I am convinced that when used properly ScratchX will do the job! I have to pick some of this up myself. Thanks!
adriankeith is offline   Reply With Quote
Old Jul 14th, 2008, 10:38 PM   #8
Hoffmann21
Hoffmann21's Avatar
Rep Power: 2 Hoffmann21 is on a distinguished road
Ok, i used it on my dads car, Very severe swirl marks, and i gotta say. I used it on a 8X8" part of the back of the car and after 3 passes by hand, 2 by buffer, and one by hand..it got out 95% out. Why does my pad turn black?(his car is black and i clayed,wash,,ect)
im confused on that. To hard of rubbing?
Hoffmann21 is offline   Reply With Quote
Old Jul 14th, 2008, 11:44 PM   #9
TimG
Learning True Art of Detailing
TimG's Avatar
Rep Power: 33 TimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond repute
MIght be you're working on a single stage paint. If so, some paint transfer will happen.
Here's the link.
How To Test for a Clearcoat or Single Stage Paint Finish
Hope that helps.
Tim
__________________
TimG is offline   Reply With Quote
Old Jul 15th, 2008, 08:35 AM   #10
Quote:
Like Tim said, it's probably a single stage paint, at least lets hope so because if it's a clear coated car and you're pulling black pigment that's a really bad sign.
What kind of car is it?
What year was it built?
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ScratchX vs. New ScratchX 2.0 (hand application) volvie! Working by Hand 13 Mar 28th, 2009 10:51 PM
Which one works tougher #80 and ScratchX, hand application irsankao Detailing 101 2 Mar 26th, 2007 01:27 PM
ScratchX - Some information about this product and removing scratches by hand Mike Phillips Detailing 101 10 Apr 17th, 2004 10:53 PM
©2004 - 2009 Meguiar's Inc.
