I've been researching various pressure washers, and not exactly sure why a detailer needs it.
Are these used to speed off the cleaning of a dirty car?
Or is it just a necessary way to be able to shoot out water from a mobile water tank that otherwise wouldn't have any pressure?
I understand that less water is consumed which is great when you are bringing your own water supply.
Isn't the potential for causing damage greater with a pressure washer?
Assuming you are equipped with a pressure washer, might there be times that you would opt NOT to use it out of fear of damaging the paint?
Finally I've seen low cost consumer 1300 PSI models, but it seems the pro models are 2000 - 3000 PSI. Is there such thing as too much PSI for our cars?
Thanks!
Richard
Thanks!
Richard
