Need some help restoring headlights
    I also bought this and I have a 3" backing plate with an interface pad as well. So I can either sand by hand or use my PC
    ^ I also take this to work at the body shop. It comes in handy
      @ pureart...petty sure 3M makes 3" sanding discs in 1200. I know for a fact they make 3"discs in the following because that's what is in their restoration kit, and what I order back-ups of. Dry finishing discs 600, 800, Trizact finishing discs 1000, 3000. The Trizact discs will last a long time do you don't have to order many. A local bpc in my town had a 3M catalog at their front desk and gets anything I need in like 2 business days, but many times already have then in stock.
        Re: Need some help restoring headlights
        2000 grit, 3000 grit then ultimate polish. Wet sand using even strokes, let the sand paper do the work dont press down too hard.
          Hi! i have a 2010 car, i think that the heathlights are ok, and i want to keep it that way ,im just buy the plastx and my question is, since i read that this is a polish, if this will afect in anything the headlight? of curse im going to use the headligth protectant after the plastx
          • #20
            You would just want to apply gently if no correction is needed.
            A mild product like ult polish would do the same though, or cleaner/wax.
            Also, the HLP is meant to bond to the headlight, so might not want to put a protectant on first.
            • #21
              I agree with Murr. A light polish such as Ultimate polish may be all you need followed by some sort of wax/sealant. Plastx is always good to have and you can follow with a wax/sealant as well.
              99 Grand Prix
              02 Camaro SS
