Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Clay Smearing.
  1. #1
    Registered Member
    Join Date
    Apr 2004
    Posts
    10
    Rep Power
    10
    Question Clay Smearing.
    Hello
    I have the Quik Clay system I have gotten in Feb 04 but got a chance to use it now due to good weather. Problem I am haveing is it Smears real bad even with alot of lube. Any way to stop it from smearing. My 04 truck is Bright Red and I had to use Medalion Paint cleaner to take smears out.
    Al
  2. #2
    Registered Member
    Join Date
    Apr 2004
    Posts
    1,228
    Rep Power
    22
    Same problem. I made sure to kneed the clay more often. Seemed to work no probs since. That was my first attempt with clay.
  3. #3
    Registered Member
    Join Date
    Apr 2004
    Posts
    10
    Rep Power
    10
    I did not even do a 1/4 of the hood. It smeared right as soon as I started. I was using lot of lube also kneeded it a bit before I started..
    Al
  4. #4
    Registered Member Mike Phillips's Avatar
    Join Date
    Jan 2004
    Location
    Stuart, Florida
    Age
    52
    Posts
    24,964
    Rep Power
    514
    Re: Clay Smearing.
    Originally posted by AL-53
    Hello
    I have the Quik Clay system I have gotten in Feb 04 but got a chance to use it now due to good weather. Problem I am having is it Smears real bad even with a lot of lube. Any way to stop it from smearing. My 04 truck is Bright Red and I had to use Medallion Paint cleaner to take smears out.
    Al
    Hi Al,
    Welcome to Meguiar’s Online!
    You know, that is one of the problems the new clay is supposed to solve. I have been using the new clay bar in the Training Garage every weekend on multiple different cars without a bad smearing problem.
    The only time I have had problems is when I have been low on lubricant, or sometimes at the end of a throw, i.e. at the end of my application motion when for a brief moment the clay has stopped on the surface while my hand changes directions. But these instances haven't been what I would call a problem and a wipe with a microfiber quickly removes any smudging.
    I have to wonder if you don't actually have the new clay bar?
    Office: 800-869-3011 x206
    Mike.Phillips@Autogeek.net
  5. #5
    Registered Member
    Join Date
    Apr 2004
    Posts
    1,228
    Rep Power
    22
    two things.. 1. was the car's paint warm? 2. After seeing a post the older quick clay was prone to some similar problems (too stickey and smears easy). To tell if you have the "new and improved" clay (which addressed the old probs) the plastic wrapper will have Meguiar's printed on it, is what I think I read. Hope this helps..
  6. #6
    Registered Member
    Join Date
    Apr 2004
    Posts
    10
    Rep Power
    10
    The clay I have is actually the older clay. I have been reading some posts and read one of yours saying the newer clay had Mequiar's printed on the clear wrapper..Well mine is plain clear wrapper...no printing on it.
    The truck was cool surface was not hot. Not here in New England yet..lol...I tried this..I got a clay magic kit to try..worked no problem..tried the Meg's the same way... Smeared under lots of lube..so I just put it in a zip lok bag and put it in my box of supplies.
    Al
  7. #7
    Join Date
    Jan 2004
    Location
    Stuart, Florida
    Age
    52
    Posts
    24,964
    Rep Power
    514
    Al
    Send me your shipping address via PM, and I'll send you Meguiar's new clay to put into your box of supplies!
  8. #8
    Registered Member
    Join Date
    Apr 2004
    Posts
    1,228
    Rep Power
    22
    Very nice Mike!
  9. #9
    Registered Member RamAirV1's Avatar
    Join Date
    Jan 2004
    Posts
    2,012
    Rep Power
    32
    I like the Clay Magic (blue) bar. It works very well and does not require as much lube as the Meguiars. It is also very easy to find locally.
    If you have a PBE nearby, see if they have the Meguairs Overspray Clay. It works very well too. It may be more aggressive and better for severe contaminants. The Overspray Clay had never smeared for me unless it it very cold.
    RamAirV1
  10. #10
    Registered Member
    Join Date
    Apr 2004
    Posts
    10
    Rep Power
    10
    What Mike offered to do for me is top notch for a person to do in my books...I am honored to me be member of this forum knowing what that good people and dedicated people belong to this forum..
    Thank You all for making this a friendly palce to visit and recieve help if needed.
    Thank You
    Al Smith
Thread Information
Users Browsing this Thread
Similar Threads
  1. Classic Clay - Early Detailing Clay - 2 Samples
    By Mike Phillips in forum Blast From The Past
    Last Post: Aug 23rd, 2008, 05:22 PM
  2. #26 smearing
    By bumboola in forum Detailing 101
    Last Post: Aug 28th, 2006, 01:35 PM
  3. What's going on here?? Smearing
    By magicman22 in forum Detailing 101
    Last Post: Mar 27th, 2006, 05:23 AM
  4. GC wash causes water smearing
    By tomee in forum Detailing 101
    Last Post: Mar 16th, 2006, 03:40 PM
  5. Meguiar's clay system: proper size of clay bar?
    By adreed24 in forum Hot Topics
    Last Post: Oct 2nd, 2005, 04:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
