Is this the same type of tool as the PC??
Hi Matt,
Here is a link which talks about that exact model: -
Also I'm sure there is someone on here uses one of these he's from Singapore or Kuala Lupar I think
Bryan
PS if you do a search, just type in the word Makita and check the "search titles only" button there is a lot of info there.
The speed and size are different than the PC dual action polisher. Also, the head size of this sander is not compatible with a backing plate that would allow you to use the foam pads for the PC, I'd be surprised if you could find foam pads for this type of tool.
I have a GMC with 125mm head and use the w8006 foam pads (6.5" I think) with no issues.
Hi Matt,
Almost every tool manufacturer has a dual action sander in their program.
Do some research and you will find numerous products, similar to the PC discussed here so often.
Examples:
DeWalt DW443
Flex X1107VE
Fein MSf 636-1
Fein MOL 1200E
Hitachi SAY150A
Festool WTS150/7
etc., etc.
or alternatively, you can choose from the twin mode (DA/RO) models, such as
Bosch GEX150 Turbo
Kress 900MPS
Festool ROTEX RO150E
...etc.
...there are soo many alternatives!!!
Good morning all,
I think I'm correct in saying that the "throw" on some orbital machines is so small it is almost the same as using a rotary, you therefore run the risk of installing the same damage that a novice might get when using a rotary.
Bryan
Originally posted by Blr123
Good morning all,
Bryan
Originally posted by Aurora40
I think the less throw, the less action. It's the fact that the pad can spin freely about it's center that makes it less dangerous then a rotary.
It is only partly true. You must set your arm speed according to the throw. For example, the Flex 1107 has one of the biggest throws with 8.8 mm. Does much more work than a 4 mm, but the latter gives a nicer, finer finish. I have a Bosch DA, which has only 4 mm pad throw, but breaks down even the coarser polishes to LSP-ready levels - thanks to its 24.000 OPM...
Blr,
The pad will do its usual DA motion while rotating, but there is no danger, because the RPMs are rather low. Most twin mode machines top out at 700 RPM.
Originally posted by Bence
[B]Aurora,
It is only partly true. You must set your arm speed according to the throw. /B]
