I've seen a good number of posting where people suggest the use of foam pads on thier buffers. I have a good number of the wool pads (with rubber boots) for my dual head orbital. Is foam better than wool? Is there a problem with wool? What is recommended and why? Any help is appreciated.
Buffing Pads
The fibers that make wool, well... wool, offer more abrading power and ability than a foam pad so they tend to remove paint and thus defects but in so doing they also instill more swirls and deeper swirls.
The type of movement action different tools generate also affects how aggressive any material is be it wool or foam, or terry cloth.
What specific type of tool do you have? A Cyclo Polisher?
I think that if we keep begging long enough that Meguiar's will make us some 4" Soft Buff pads to use with both the PC and Cyclo. HINT!!!!!
Yes, using foam pads with the Cyclo will produce better results than using the wool pads. If you take a look at exceldetail.com you will find a whole set of pads intended for use with the Cyclo.
I'm sure Accumulator will chime in soon....countingQuadruple Honda Owner
Black cars are easy!
