Results 1 to 10 of 19
Thread: white streaks in clearcoat
    Jul 2005
    4
    Unhappy white streaks in clearcoat
    I'll spare you the details, but I committed a blunder by applying Meguiars #7 showcar glaze onto a hot surface (clearly stated on the label). I immediately removed it, but it left white streaks in the clearcoat. They can not be seen by looking directly onto the defect, only at an acute angle. I have been moderately aggressive in trying to polish them out, but no statisfactory visible improvement. The car was repainted two years ago with PPG basecoat/clearcoat system and always garaged kept. Any help would be greatly appreciated. Thanks
    Okanagan Valley, BC
    4,544
    391
    Hey mac'smach1
    Welcome to Meguiar's Online!
    I would suggest re-applying the #7 Show Car Glaze but in the shade on a cool surface. If this does not do it, though it probably will, you will need to clean/polish the paint first with something like #9 Swirl Remover, then the #7 and the sealant/wax of your choice.
    Please keep us posted!
    Tim
    57
    24,796
    517
    Hi mac'smach1,
    Sounds like you need to use either a cleaner/polish like the #9 Swirl Remover Tim recommended or a paint cleaner like either Deep Crystal Paint Cleaner or ScratchX, all three of these are fairly easy to find at most auto parts stores.
    Apply any of them to the affected area or the entire car, work in gently and then remove, none of these products need to dry. Afterwards, it would be a good idea to either apply the #7 Show Car Glaze followed by a coat of wax, or just a coat of wax, the point is a paint cleaner will clean paint, remove defects and in the process also remove any wax, so keep this in mind.
    Jul 2005
    4
    Thanks for the responses, they are greatly appreciated. My concern is that there was a chemical reaction (due to the heat) and the blemish is deep into the clearcoat. I already buffed with Meguiar's #7 and then Fine Cut and no luck. It does not appear to be on the surface or it would gone by now. I'm just not sure how far I can go before I'm through the clearcoat. It's right in the middle of the hood on my '65 (Senior AACA) Mustang FB. If it was on my daily driver I probably would not worry about it. Thanks again.
    57
    24,796
    517
    Just to be clear, when you say you buffed, is this all by hand, or are you using some kind of machine?
    The old formula for #2 Fine Cut Cleaner is for rotary buffer application only so I don't want you to get into trouble if you're hand applying this product. The new formula can be applied by hand, the instructions on the back will state how it can be applied and enable you to know which version you have.
    #7 is a very safe product chemically speaking, the heat could have and probably did have a lot to do with this problem. Clear coat paints are typically pretty hard and pretty dense, I wouldn't think the damage would be very deep but more topical.
    AT this point, if you are working by hand, I would suggest getting a tube of ScratchX and applying 2-3 applications to the area using a clean foam applicator pad. Work each application for 1-2 minutes or until the product turns kind of clear then remove it with a clean soft towel. After this apply a thin coat of the #7 and wipe off and then a coat of your favorite wax.
    Another approach would be to machine clean and polish the area with either a dual action polisher or a rotary buffer and a light cleaner/polish like the M80 Speed Glaze.
    If you e-mail me your phone number, I would be glad to discuss this in person. mphillips@meguiars.com
    I'm getting ready to go wash a Corvette for a how-to article but I'll be checking my e-mail often.
    Okanagan Valley, BC
    4,544
    391
    Hey,
    Do you have some pictures you can post of the streaks? I would like to see what we are dealing with....
    I would still give the #9 a shot, or the more aggressive ScratchX. Either one, you need to apply it, and really work it in until it is a light residue. Then remove with a MF towel.
    Please post some pics of the area.... we will do our best to figure this out!
    Tim
    366
    18
    Since your car was repainted two years ago, it may never have the hardness and durability of factory applied original paint.
    FRANK CANNA
    Mirror Finish Detailing
    23rd Year 1986-2009
    Jul 2005
    4
    I used my Dewalt 849 rotary sander/polisher with the #7 Show Car Glaze, Fine Cut and Cleaner & Wax. I have to admit I am very conservative (timid) when it comes to using this tool and kept the speed to around 1200-1500 RPM. I only have a black foam bonnet which I am told is for final polishing.
    I bought a tube of the ScratchX and went on it six times by hand only, sometimes very aggressively to some of the worst areas, but no help. I will try to take a photograph of it, but will not be able to send until Monday. I am not sure it will show up in a photograph, but I will try.
    Again, you can best see these things in the sunlight when looking at a very low angle to the surface. They are very, very hard to detect when the vehicle is not in the sunlight or at a high angle. My guess is that when looking at it directly there is not enough clearcoat thickness for the blemish to show, but at the low angle you are starting to look through the cross-section containing a much larger area. I forgot to mention my FB is painted dark green metallic. Thanks again for trying to help me.
    57
    24,796
    517
    A couple of notes,
    #7 is for hand application only, it doesn't work very well when applied with a rotary buffer and was never intended for, or formulated for application with this tool.
    Same goes for our Meguiar's brand cleaner/wax, you didn't say which cleaner/wax you're using, but if it's in the maroon bottle, it is also for hand application.
    #2 Fine Cut Cleaner is for application with a rotary buffer and if a couple of light passes with a foam pad on a rotary buffer didn't fix the problem, then this isn't a good sign as the #2 Fine Cut Cleaner applied with a rotary buffer should take care of anything that's light and topical.
    Catalyzed clear coats are hard and dense, its very unlikely that #7 on the surface getting hot would stain into it for any measurable depth, it's just not that kind of product unless there is something wrong with the paint to start with.
    57
    24,796
    517
    This would help if you can capture it.
    Is all this inspecting taking place after the cleaning step, or after applying polish and wax? Sometimes we have people posting comments about results before they have finished the process. Polish and wax build on the results created by a paint cleaner. The process isn't finished at the cleaning step.
  1. Streaks in paint
    By eric96ser in forum Detailing 101
    Last Post: Apr 30th, 2008, 04:05 AM
  2. Cleaning/prepping/waxing non-clearcoat white paint
    By Shevy11 in forum Detailing 101
    Last Post: Feb 12th, 2008, 11:17 AM
  3. HELP! White water spots and streaks on wheels
    By johnnyrmtl in forum Detailing 101
    Last Post: May 1st, 2006, 01:51 PM
  4. Streaks in paint
    By Accident in forum Detailing 101
    Last Post: Jan 22nd, 2006, 11:57 AM
  5. got streaks from colorx
    By substance12 in forum Detailing 101
    Last Post: Aug 2nd, 2004, 04:43 PM
