has anyone got info on the high tech yellow wax megiures use to have ? GEO
High tech yellow wax
Re: High tech yellow wax
Meguiar's #26 is a hugely popular blended wax! It works fantastic, especially on reds and blacks! It creates a deep, warm, rich glow to the paint. Here is a link to the #26
#26 Hi Tech Yellow Wax
Tim
Hi geoofruskin,
Welcome to Meguiar's Online!
Check this out...
What are the differences between Meguiar's waxes?
There's some information on M26. Great wax, been around for a long time, creates a very clear, rich reflective finish. It's unique in that it doesn't dry white, to know when to wipe it off you really need to use the Swipe Test.
How to tell when a Meguiar's wax is ready to remove - The Swipe Test
Re: Re: High tech yellow wax
Tim
Re: Re: Re: High tech yellow wax
Thanks all for the replies. i looked at the link but i use to get it in a small tin with an applicator .I like the wax because it doesnt leave a white haze residue in the cracks and crevices .and it is easy to work .You dont have to work your fanny off like the old Blue Coral . also do they have a plastic cleaner for the Headlight lenses . GEO
Tim
Originally posted by Rusty Bumper
I wonder if #26 is going to be able to meet the new VOC rules?
I hear that some Carnauba waxes are not going to be able to comply.
Get yourself a bottle of PlastX, you won't be dissapointed... You'll see this products listed at the bottom of this reply. I've included a reply from another post to share all the Meguiar's Plastic products and some information about each one.
Originally posted by adreed24
I have never used "PlastX", but I was wondering if it should be used for maintaining and protecting new vehicle plastic OR should it be used strictly for restoring older plastic?
I thought that since "PlastX" removes scratches, it might be too strong or abrasive, for newer plastic.
Any ideas?
Thanks in advance
Below are all 4 of Meguiar's Plastic products, M10 Plastic polish is a non-abrasive, non-cleaning polish formulated specifically for maintaining clear plastic surfaces. This would probably be a good choice to start with.
Mirror Glaze Clear Plastic Polish
The finishing touch for maximum clarity and brilliance. Meguiar’s Plastic Polish provides the second step in our two-step restoration process for clear plastics. One easy application protects surfaces previously cleaned with our M-1708 Plastic Cleaner. You will reveal the materials natural brilliance, while leaving behind an anti-static coating that helps repel damaging dust and dirt.
M-1008 ....................8 oz. (237 ml) $9.98
Mirror Glaze Clear Plastic Cleaner
Safely removes hairline scratches, dirt and grime. Clear plastic that has lost its clarity due to significant contamination and fine scratches should be treated using our two-step process. Meguiar’s non-abrasive, alcohol-free Plastic Cleaner aggressively cleans and removes scratches without harming the surface. Follow up with our M-1008 Plastic Polish for a perfect finish.
M-1708 ....................8 oz. (237 ml) $9.98
Mirror Glaze Clear Plastic Detailer
A single-step solution that keeps clear plastic surfaces pristine. Regain the original crystalline clarity of plastic in need of restoration, using this convenient all-in-one product specially formulated by Meguiar’s. Simply spray it on and wipe it dry. You will safely remove surface contamination and achieve dramatic results on everything from window panels and instrument lenses to eyeglasses, CDs and picture frames.
M-1808 ....................8 oz. (237 ml) $8.98
PlastX
This easy to use, rich gel formula quickly restores optical clarity to both rigid and flexible plastics. Cutting-edge advancements in Meguiar's exclusive Microscopic Diminishing Abrasive Technology, (MDAT), removes light oxidation, chemical degradation, surface contamination, stains and light surface scratches with ease. In addition, because our microscopic diminishing abrasives breakdown as you use them, PlastX Clear Plastic Cleaner & Polish is safe on plastic rear windows on convertible tops, aircraft windows, motorcycle fairings, face shields, headlights and taillights, instrument panels, all clear plastic boat surfaces and aquariums. Meguiar's PlastX also contains highly water-resistant polymers. These specialized hi-tech polymers provide long lasting durable protection to keep your clear plastics clear and beautiful longer. PlastX is non-toxic and does not contain any harsh solvents.
G-12310 ....................10 oz. (296 ml) $4.99
Is PlastX stronger than #17?
Plastic Cleaner as far as I know uses chemical cleaning action only. PlastX is much better at actually removing a scratch out of plastic.
PlastX contains special microscopic diminishing abrasives to make it a more powerful and effective defect remover compared to M17 Plastic Cleaner.
I'll pick up some soon.
Edit: Seems like I remember feeling some fine abrasives in #17 though.r. b.
Must have been some dirt on your fingers?
Shake the bottle up very well and feel again, it will feel like rich high lubricity lotion.
But it does sound a little gritty when I am rubbing it in with a piece of cloth.......Maybe it's the cloth that's fooling me.r. b.
