Results 1 to 2 of 2
Thread: Clear Coat Problem / Turned Milky White in Spots
    Registered Member 192 Viper's Avatar
    Aug 2004
    14
    I bought an 87 Lotus Esprit over the winter months. Last month (early June) I washed/clayed/hand glaze/polish/NXT Paste. I put a cover on the car and left it outside. Well it rained for 3 days while parked outside. When I took the cover off I noticed some blotchy spots on the car. Like moisture got under the clear coat. I figured over time the moisture would dry and the spots would go away. But it still remains after about a month of being in and out of the sun, and parked in the garage.
    Any advise on how to make it go away...?
    Thanks,-Jeff
    92 Dodge Viper #192/285
    57
    24,796
    517
    Try cleaning, polishing and waxing one small area.
    Use some ScratchX, or Deep Crystal Paint Cleaner, apply, work in, and remove from an area about 8" square or so. Then apply a polish and then a wax. Basically, try doing the things you would normally do in a detailing session and then inspect the results of that one area as compared to the rest of the car.
    For the most part, if the problem is on the surface, the ScratchX should fix it. If the problem is throughout the matrix of the clearcoat, then I'm not sure what to think or to tell you.
    Try the above recommendation first and see what happens if for no other reason that is the simple fix.
    Keep us posted of your results...
  1. Detailed: Perodua Myvi Special Edition - Milky White
    By TimG in forum Show Off Your Latest Detail Work
    Last Post: Dec 2nd, 2008, 04:26 PM
  2. Problem after debadging my car. Missing clear coat?
    By T3hD0gg in forum Detailing 101
    Last Post: Jul 17th, 2008, 04:00 PM
  3. Water spots under the clear coat?
    By Cleetus in forum Detailing 101
    Last Post: Sep 15th, 2006, 05:13 PM
  4. Red Trans Am has milky,white appearance, HELP!
    By adreed24 in forum Detailing 101
    Last Post: Mar 16th, 2005, 10:49 PM
  5. Clear coat problem
    By geoff in forum Detailing 101
    Last Post: Oct 17th, 2004, 07:56 PM
