Polishing over Vinyl Graphics?
  • Polishing over Vinyl Graphics?
    Ok, this is the procedure i was planning on doing:
    -Wash NXT
    -Clay
    -Wash NXT
    -#83 with DAP
    -#80 with DAP
    I'm going to be adding a few Vinyl graphics (spider webbing deisgns) so...
    -Rubbing Alcohol with MF Towel (only in areas where Vinyl will be applied)
    -Apply Graphics using Squeege, apply dishsoap and water to "move and set" graphic into place
    -wash NXT
    -Sealent
    -Wax
    Now, should I switch the order of anything? or should something else be changed?
    Also, in 6 months when I strip the wax and sealent off and reapply... will I be able to use #83 and #80 with a DAP over the Vinyl (if nessesary)?
    Thanks!
    bump
    'cause i'm curious also
    oops, ok, never mind
    See Kevin's '03 PT Cruiser GT here: http://www.cardomain.com/ride/477590
      Re: Polishing over Vinyl Graphics?
      -Wash NXT
      -Clay
      -Wash NXT
      -#83 with DAP
      -#80 with DAP
      That looks good.
      Also, in 6 months when I strip the wax and sealant off and reapply... will I be able to use #83 and #80 with a DAP over the Vinyl (if necessary)?
      Thanks!
      Depends on the quality of the vinyl graphics. Without seeing them I would say for sure avoid using the M83, and a maybe on the M80, again it just depends on the quality of the vinyl graphics.
      Best bet would be to only wax around the graphics and not use a cleaner/polish.
        Since my new shop opened up i had to delay polishing the car and putting the graphics on... just so happins i'm hopeing to get to the polishing next week and a little touch-up painting spots after I clay and before I go over her with 83
          Where's your new shop? What do you do there?
          Inquiring minds want to know?
            It's a semi-fast food resturant with Pizza, Subs, Burgers... and so on...
            It's about 1 hour South of Chicago right off of the Interstate...
            Hey, when you guys are ready to go on the road... we'll have Detailing days at my shop, free food for all particapents
