Page 6 of 6 FirstFirst 123456
Results 51 to 58 of 58
Thread: How To Remove Swirls By Hand
  1. #51
    Registered Member
    Join Date
    Jun 2012
    Location
    Klamath Falls, OR
    Posts
    22
    Rep Power
    1
    Re: How To Remove Swirls By Hand
    I don't mean this in any negative way, however after seeing the before and after pictures, yes there was a difference. But that's not the type of shine I would expect after all that rubbing. Wouldn't a buffer have worked faster and better?
  2. #52
    Formerly 101impala Moderator Andy M.'s Avatar
    Join Date
    May 2004
    Location
    Philadelphia, PA
    Age
    45
    Posts
    3,954
    Rep Power
    341
    Quote Originally Posted by Slidder View Post
    The purpose of the thread was to show you how to remove swirls by hand. To answer your question yes a buffer would have been faster, but as stated in the thread not everyone has one.
    Andy M. Moderator
  3. #53
    Registered Member Mike Phillips's Avatar
    Join Date
    Jan 2004
    Location
    Stuart, Florida
    Age
    52
    Posts
    24,964
    Rep Power
    514
    Hi Slidder,
    To your question,
    "yes". You make the same point I made for years teaching the Saturday 101 Classes here and now in Florida. You ALWAYS get better results by machine versus working by hand because the paints changed and modern clear coat paints are harder than traditional single stage paints and you with your hand can only do so much. The machine never gets tired and moves a buffing pad under pressure at a high OPM rate and together with the right chemicals and techniques even a beginner can create show car results.
    I took these pictures and removing swirls by hand is no easy feat, so actually, the results you see are very good. That was the other point made in the class and that was to teach people that didn't own a polisher how to work by hand.
    Actually, the amount of ROTARY BUFFER induced swirls removed working only by hand is dramatic.
    Before
    After
    Of course, after demonstrating how much time and work it takes to remove only a majority of the swirls by hand then demonstrating how easy it is to let the machine do all the work, most of the people going through these classes back then and even today under Mike Stoops leads to the sales of more and more polishers.
    In my how-to book, "The art of detailing", I make this point in the first chapter that discusses the history of paint and then again in the chapter the explains how the drive mechanism in tools like the Meguiar's G110v2 work to remove swirls but at the same time are very safe.
    You can read more in my articles here,
    The Free Floating Spindle Assembly - The Story Behind The Story... by Mike Phillips
    Here's an excerpt from the above article,
    Quote Originally Posted by Mike Phillips
    The practical differences between single stage paints and a clear coat paints
    Early 1965 Mustang with single stage paint and a modern Mustang with a basecoat/clear coat finish
    Frustration with clearcoat paints
    Now let me tie this back to why machine polishing has become so much more popular since clear coat paints were introduced.
    As more and more cars being manufactured made their way into the market, as car owners, or in other words, do-it-yourselfers, would try the traditional methods of removing defects out of the paint, that is with traditional rubbing and polishing compounds, they would find that most of these products may remove defects but leave their own defects in the paint at the same time.
    Not only that, but because generally speaking, modern clear coats are harder than single stage paints, the energy, time and skill required to actually remove defects out of clear coat paints increased dramatically, and in fact increased to the point that many people attempting to remove defects and restore a shine like their car had when they bought it brand new, left most people feeling frustrated and their cars no better off than when they started and often times worse.
    Enter the Porter Cable DA Sander
    That's right, I said sander! The Porter Cable Dual Action Sander is the tool that became the Tipping Point that was the driving force behind the average person switching from working by hand to working by machine.
    Office: 800-869-3011 x206
    Mike.Phillips@Autogeek.net
  4. #54
    Registered Member
    Join Date
    Aug 2012
    Location
    NYC, NY
    Posts
    6
    Rep Power
    1
    Hello Mike.
    I am new into detailing and regularly synthetic wax on monthly basis and wax with gold class weekly but still my cars have developed slight cobweb swirls.
    I recently came across this thread but since this procedure and products date back to 2005 i was wondering if you may recommend new products or replace certain products that you have used in this thread to remove swirls.
  5. #55
    Join Date
    Oct 2004
    Location
    Pittsburgh, PA
    Age
    32
    Posts
    18,014
    Rep Power
    219
    Ultimate Compound would be the product for removing swirls by hand these days.
    However, be sure to use a good applicator like shown, and similar technique with good even pressure.
    Could look at Ult. Polish to follow up with, then something like the Nxt 2.0 wax, Ult. Wax, etc.
  6. #56
    Registered Member ffboy's Avatar
    Join Date
    Oct 2010
    Location
    manila, philippines
    Posts
    933
    Rep Power
    12
    After removing the swirls, you do want to practice proper paint maintenance to avoid or at least minimize those swirls from reoccurring. Swirling can come from anywhere... from improper carwash techniques (which I personally rank highest among swirl producing procedures) to contaminated wax/cleaner applicators.
  7. #57
    Registered Member
    Join Date
    Aug 2012
    Location
    Garage
    Posts
    2
    Rep Power
    1
    So what I would do for a good detail is:?
    1. wash car
    2. clean with scratch x
    3. wax it with meguiars tech wax
  8. #58
    Join Date
    Oct 2010
    Location
    manila, philippines
    Posts
    933
    Rep Power
    12
    I would:
    1. Wash car
    2. Clay bar
    3. Depending on the degree or amount of scratches/swirls on the paint. ScratchX 2.0 will remove deeper scratches and may be better for smaller work areas, for lighter swirls or refining, swirlX or ultimate polish. For faster detailing, Cleaner Wax or ColorX can be used, especially if the paint isn't too badly swirled up, it will clean, polish protect in 1 simple step.
    4. Wax with NXT 2.0, Ultimate wax or Gold Class, choice of wax is up to you.
Thread Information
Users Browsing this Thread
There are currently 2 users browsing this thread. (0 members and 2 guests)
Similar Threads
  1. best product to remove swirls by hand???
    By jaxxx in forum Working by Hand
    Last Post: Feb 18th, 2009, 10:24 AM
  2. Tried to remove swirls by hand...
    By EV0B0Y691 in forum Detailing 101
    Last Post: Mar 13th, 2007, 08:33 PM
  3. How to remove swirls by HAND with scratch X?
    By SUBARU WRX in forum Detailing for dollars
    Last Post: Dec 26th, 2006, 06:49 PM
  4. Removing Swirls by hand
    By manueljlg in forum Detailing 101
    Last Post: Apr 4th, 2004, 02:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
