Winter Detailing
Results 1 to 7 of 7
Thread: Winter Detailing
    Rob bowlerr's Avatar
    Aug 2017
    Alamogordo, NM
    38
    38
    Winter Detailing
    So a couple questions about detailing a car during the winter. I know from reading here that Megs products are not recommended to be used below 55F, but does this have to do with the ambient air temperature or the temperature of the surface of the car? For example, in southern New Mexico we will get below 55F on many days during the winter but the sun will be out most of the time. With my black car absorbing the energy of the sun the surface of the car can get above 55F but not into the extreme heat of the summer. So I guess the questions are:
    1. Is the 55F limit more important for the ambient temperature or the surface temperature of the car?
    2. Would I be able to apply the products that say to not apply in the sun due to the lower temperatures outside?
    Just trying to figure this out because I will have no garage to work in but I just got a new black car, so work will need to be done.
    Aug 2017
    Alamogordo, NM
    38
    38
    Re: Winter Detailing
    Nothing from anyone? That's depressing.
    Apr 2007
    US
    1,065
    22
    I have no clue if it is surface or ambient temperature. What I do know is that I waxed a car a couple of years ago in my garage, and the thermometer read 48 degrees. Set up time was longer. As for waxing in the sun to get the surface temperature up, perhaps do a scientific experiment and live dangerously. Dab some wax on, maybe a foot square, and record the ambient and surface temps. You should quickly find the answer to your question.
    Feb 2004
    Southeast Nebraska
    912
    26
    I know the recommended temperature for not waxing is 55 degrees, but I have applied Meg's products at lower temperatures...but not below 45 degrees. A lot depends on the product you use. I think that I'd stick with an easy to apply and remove all in one cleaner wax like Meg's inexpensive Cleaner Wax in the burgundy bottle. Apply a very thin coat. It will probably be harder to remove than it would be at a higher temperature. When spring arrives, do a complete detail with your product of choice.
    38
    19,005
    234
    Probably a bit of both. If it gets too cold/damp overall, the products just get hard to work around and remove. I waxed my car the other week up here, and the wax smeared a little. Oh well, the dirt covered it right back up anyway.
    Yeah, for sure. Sunlight is a good thing when it is cool out, esp with waxes to help them dry. If i know it is cool/cold, I tend to stick with cleaner/waxes or waxes... polishes and things that say to remove before drying can still be a bit tricky.
    Aug 2017
    Alamogordo, NM
    38
    38
    OK, I think that's basically the answer I'm looking for. I'm not looking to go all out on the car but primarily getting it to the point where it looks good (doesn't have to be great yet) and got some protection on there till it starts to warm up in the spring and I can go more all out on it.
    Aug 2010
    Memphis, TN ~ USA 1
    458
    I've worked in temps down in the 30's using Meguiars products with no noticeable effects
  1. Detailing in winter?
    By trailblazer295 in forum Detailing 101
    Last Post: Feb 4th, 2017, 11:08 AM
  2. Mobile Detailing - During the winter?
    By Show N Tell in forum Detailing 101
    Last Post: Aug 25th, 2010, 05:16 AM
  3. Winter detailing?
    By CumminsCrazed in forum Detailing 101
    Last Post: Nov 1st, 2009, 06:22 PM
  4. Detailing in the Winter
    By Ol' Red in forum Detailing 101
    Last Post: Aug 7th, 2009, 05:43 PM
  5. Detailing in the winter DUCKS
    By Tungsten in forum The Break Room
    Last Post: Dec 4th, 2006, 08:31 PM
