Good Evening all!
I recently purchased a magnetic metallic grey 2015 Ford Taurus SHO. The paint seems to be in decent shape, there are a few scratches here and there, around the handles and on the trunk. There are also multiple rock chips on the front end of the car. I'm not sure if the metallic paint is just covering it up, but I don't see any major swirling either. My goal is to attempt to remove the scratches, polish it up, and seal the paint before winter strikes.
This week I purchased a Porter Cable 7424, and it came with M105, M205 and a set of Meguiars pads. I have a couple of questions before I attempt to clean up the paint.
1) Much of the car is in pretty good shape, but I wanted to use the M205 and a fine pad and try and maximize the shine. Should I use a finishing pad, or the polishing pad that came with the kit?
2) Some areas have scratches, is it okay to use heavier compounds on isolated parts of the car? I'm worried about making the finish look patchy. I was even thinking of just using M205 with a cutting pad to keep from being too aggressive.
3) I've watched quite a few youtube videos on polishing. The one thing that isn't that clear to me is how long you polish until you wipe the product off? It should go until the abrasive breaks down and it lightens up, correct?
Thanks for asking my newbie questions. I just don't want to end up like some of the other guys that post here with trashed paint jobs after they got a little over zealous!
Phil
Phil
