Results 1 to 7 of 7
Thread: Wet sanding
  1. #1
    Registered Member
    Join Date
    Oct 2017
    Location
    Na
    Posts
    5
    Rep Power
    1
    Wet sanding
    When using the Meguiar's 2000 grit paper with
    sanding backing pad (wet sending by hand)
    Is it better to wetsand in a straight forward and backwards motion if not what is the correct way of doing this?
    And what compound to buff out will m105 be fine?
  2. #2
    Registered Member
    Join Date
    Sep 2015
    Location
    Montreal, QC, Canada
    Posts
    28
    Rep Power
    3
    Re: Wet sanding
    Watch this one carefully. Maybe it will help.
  3. #3
    Join Date
    Sep 2010
    Location
    Irvine, CA
    Posts
    4,924
    Rep Power
    57
    Re: Wet sanding
    Welcome to Meguiar's Online. M105 Ultra Cut Compound will remove up to 1200 grit sanding marks when used with a rotary polisher machine and the appropriate pad. So yes, M105 is perfectly suitable for buffing out sanding marks. In fact, M105 is our most premium cutting & finishing compound we produce.
    In regards to hand sanding technique, instead of me writing a huge long response, check out the below thread. There is detailed information on hand sanding techniques, DA Sanding Techniques, and Rotary Polishing Techniques w/ video:
    Pictures from Meguiar's March 26th, 2017 Intro to Wet Sanding & Rotary Polishing Class
    Hope this helps.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
    800-854-8073 ext 3845
  4. #4
    Registered Member
    Join Date
    Oct 2017
    Location
    Na
    Posts
    5
    Rep Power
    1
    Re: Wet sanding
    So i had a panel resprayed and on closer inspection can see a few dirt nibs and minor paint imperfections.
    Maybe orange peel?
    Should i wed sand the whole area or just the nibs and imperfections?
  5. #5
    Registered Member
    Join Date
    Sep 2015
    Location
    Posts
    28
    Rep Power
    3
    Re: Wet sanding
    I certainly don't qualify to answer this so take it with a grain of salt but:
    Depends entirely on what you are shooting for.
    If you want a showcase finish, you'll have to wet sand the whole car (the quality of reflections on the pictures seems to show orange peel about everywhere, which would be expected).
    If you are aiming to fix the most annoying imperfections only, restrict your work to 2x2s areas around them so that they blend nicely.
    you call
  6. #6
    Registered Member
    Join Date
    Oct 2017
    Location
    Na
    Posts
    5
    Rep Power
    1
    Re: Wet sanding
    Quote Originally Posted by CrazyVinny View Post
    you call
    Yes i would like to fix the imperfections that are in various places of the car and have an overall shine on the entire car.
    So could either use a trizac 3m disc or a megulars disc i take it there's not much difference between the two?
  7. #7
    Registered Member
    Join Date
    Sep 2015
    Location
    Posts
    28
    Rep Power
    3
    Re: Wet sanding
    Once again, I'm thoroughly NOT qualified to answer any of this. I'm just a week-end warrior that did a lot of research.
    Hopefully, someone with actual experience will take pity on you and answer your questions more definitely than I can.
    If you want my two-cents tho, I'd say 3M cutting disks will be required for levelling and Unigrit 3k foam-interfaced for refining/matching.
    Jason Rose goes over the essential difference between the two types of sanding disks in this video.
    Good luck.
    Crazy Vinny
Thread Information
Users Browsing this Thread
Similar Threads
  1. damp sanding process with Meg's sanding discs - 1500 film followed by 1500 foam?
    By InfiniteDetail in forum Wet-Sanding/Color Sanding Automotive Paint
    Last Post: Sep 11th, 2013, 02:21 PM
  2. What's the difference between wet sanding and dry sanding using a DA polisher ?
    By asalah in forum Wet-Sanding/Color Sanding Automotive Paint
    Last Post: Jan 9th, 2012, 08:20 AM
  3. Sanding
    By AeroCleanse in forum Detailing for dollars
    Last Post: Aug 21st, 2008, 12:44 PM
  4. wet sanding
    By AUTODBAY1 in forum Introduce Yourself - New MOL Members
    Last Post: Apr 28th, 2008, 03:50 PM
  5. wet sanding runs n drips w/ the sanding block
    By WhiteCamaro88 in forum Wet-Sanding/Color Sanding Automotive Paint
    Last Post: Oct 17th, 2005, 12:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
