I just did my pre-winter wash and seal the other day, which is basically:
It looks great and shines up real nice, but I noticed a few dark spots in some areas under close inspection with a spot light:
These were not present beforehand.
Some possibilities:
- two-bucket wash with meg's gold class soap
- two-bucket wipe down and dry with ONR
- Opti-Seal (synthetic polymer sealant)
Some possibilities:
- I may have applied a bit too much sealant (I was eager and didn't review enough instruction ). If that's the case, with these will just fade over time as the sealant wears? These spots are only visible in a dark environment with a spot light. I couldn't see them in hard, direct sunlight.
- Moisture trapped under the sealant? I tried my darndest to make sure it was completely dry.
- Clearcoat marring from buffing too aggressively?
