Ultimate wash and wax dilution
Results 1 to 8 of 8
Thread: Ultimate wash and wax dilution
    Registered Member snozan's Avatar
    Jul 2016
    Sweden
    41
    119
    3
    What dilution do people use?
    I know it says 1 ounce for 1 gallon of water. But thats pretty massive consider that you need like 1 ounce to 3 gallons of water with Mothers Wash and wax.
    So what do people use? As it says on the bottle or some own mix.
    Jun 2005
    The Real NorCal
    4,103
    143
    Re: Ultimate wash and wax dilution
    1oz per gallon.
    Jul 2016
    Sweden
    41
    119
    3
    So everyone experiment with everything except the schampo? Find it hard to believe everyone uses like what it says on the bottle. If so, there is no point in buying it, since you get out more washes of the Mothers wash & wax, only difference is that Mothers have Carnauba. It holds 64oz vs Meguiars 48oz and the price (here in Sweden) are the same for both.
    Jun 2005
    The Real NorCal
    4,103
    143
    The soap is what provides lubrication to prevent scratching while washing my cars. Personally, I'm not going to try and save a few cents each time I wash my car by not following the recommended dilution ratio. I'd also rather not have to spend more time and money to remove scratches and swirls that were created because I wanted to use less soap. As for price, it is what it is on our end. We have no control over it. I'll gladly spend more money for the Meguiar's product because I know it is a good product. If I was going for cost, I'd just buy the 100oz jug of Blue Coral soap for $3.88 vs. $9.30 for 48oz. of Ultimate Wash and Wax or $9 for 64oz. of Gold Class. I'm know I'm not speaking for everyone...that's just my $0.02.
    Jul 2016
    Sweden
    41
    119
    3
    Question is, how do you scratch your car while washing it? And you answered my question without knowing it. So the amount of soap is only for lubrication.
    I rinse my car thoroughly with high pressure wash. Really take the time to get all of that loose dirt off. Am no fan of a neither a grit guard or two buckets, beacuse if you need that, you need to rinse your car more carefully before washing it.
    I used 2 oz in 3 gallons of water, but that felt like too much. Didnt really feel like i was washing, more like smear some oil over the paint. So i'll try to go down to 1oz of 3 gallons of water instead =)
    Jun 2005
    The Real NorCal
    4,103
    143
    How? Many, many ways to scratch it while washing. It'd probably be easier to say you decrease your chances by following the basics such as using a clean wash mitt and using the proper amount of soap. You can also add extras for a reduced chance of inducing scratches or swirls like the two bucket method with grit guards and using a QD as a drying aid with a good quality drying towel. Do you need two buckets or grit guards? No. It's simply extra to help reduce the chance of damaging the paint.
    It sounds like you might enjoy Hyper Wash. It's like $20-$25 for a 128oz, but you only need 1oz of it for every 3-5 gallons of water. It isn't a fancy car shampoo, but it'll get the job done and last a long time without using a lot of product every wash.
    Aug 2014
    anaheim hills, ca
    76
    4
    Water has an encapsulating effect (that is how rinseless or waterless washes are possible...generally speaking as it is much more complicated then that scientifically). Because the water encapsulate dirt, those dirt particles are carried across the paint surface. Car soap adds lubrication or a protective barrier between the water and the surface to reduce friction and micro-marring from dirt gliding/scrating/grinding into the painted surface. If using a bucket method to wash, it is recommended to use 2 or 3 buckets (the 3rd specifically for wheels) with grit guards in both with a dedicated rinse and wash bucket. This ensures that the dirt/grime collected as you glide your wash media and washing device across the surface can be rinsed out and trapped with the grit guards. Dunking the mit into the soapy water restarts that process with a clean surface. Proper washing techniques are vital to ensure that your car does not end up getting swirls and "love" marks.
    I agree with "roushstage2" that soap should be used as directed and not diluted. If you want to dilute, use a concentrated soap like Meg's Hyperwash (D110) or Meg's Rinse Free Wash and Wax (D115). For Meg's Rinse Free Wash and Wax I dilute to the recommended 256:1 (using DI water) and pre-soak MF towels with a gamma seal lid. I pre-soak the car with the same dilution ratio like I was using waterless wash system and fold my towels into 4. Using 1 fold of the towel per panel with a Meg's modified gary dean method of washing, I can wash the car with 3 towels (2 for wash totally 8 sides and 1 for drying)
    Theoretically, depending on how hard your water is, you can use less soap for the same lubrication properties with cleaner water. Over generalized, 1 gallon of DI water with 1 oz of Ultimate Wash will allow give the same lubrication properties as 1 gallon of water (with say approx. 400ppm) and 3 oz of soap.
    Jul 2016
    Sweden
    41
    119
    3
    Quote Originally Posted by twisty roads View Post
    Good points! I take it as it differ quite in washing a car in US vs Sweden. As i said, here it says if you need 2 buckets, you havn't rinsed down your car enough before washing it. I hardly doubt there is some stubborn dirt on the paint (Clay/UC/UP/ULW/UFF). We dont have any heavy pollution. I guess i choosed the wrong word for my question, i should have used "mix ratio" (schampo/water). However i liked the idea of Hyper wash, i'll have a look into it (after the Meguiars and Mothers bottles are empty)
    This is the water qulity in Sweden. Its consider "soft water". Guess after all, i'll use 1,5 oz for 2,1 gallon of water =)
  1. Hyper Wash dilution ratio with Pressure Washer
    By seanzh82 in forum Detailing 101
    Last Post: Feb 7th, 2017, 11:58 AM
  2. RFEW dilution level for waterless wash?
    By smack in forum Professional Line - Mirror Glaze & Detailer Line Product Discussion
    Last Post: Apr 11th, 2012, 01:45 PM
  3. Does correct dilution ratio really matter on car wash?
    By Lynx131 in forum Detailing 101
    Last Post: Jun 4th, 2011, 09:32 PM
  4. D11001 Hyper wash - foam gun dilution ratio
    By Love Eleanor in forum Professional Line - Mirror Glaze & Detailer Line Product Discussion
    Last Post: Jul 31st, 2010, 11:05 AM
  5. Wrong car wash dilution
    By EPHIOS in forum Consumer Line - Product Discussion
    Last Post: Apr 3rd, 2010, 05:16 AM
