What the hell is happening to my headlights?
Results 1 to 10 of 14
Thread: What the hell is happening to my headlights?
    Jan 2017
    miami
    76
    I don't know if this is condensation or what. It does not seem to be water in there, more like is fogged up from the inside. How is it possible that it has happened to both headlights and is only on the upper part, but the middle and bottom is crystal clear. I'm thinking about removing the high beam bulb and using a compressor to spray air into the housing, but I don't know if this will fix it or make it worse. I contacted a headlight restorers and nobody wants to try and fix, most of those guys all they do is treat the outside of the headlights and I can see why they wouldn't want cause they could mess something up and they'd rather avoid any possible risk.
    It is a 2014 vehicle and I bought it used in 2016. It already had some of this, but very little, it has gotten worse. How could this happen to both headlights and on the top part. Someone told me it could be clear coat peeling, but on a 2014? That's ridiculous.
    Michael The Guz's Avatar
    Jul 2013
    Lawndale, CA
    39
    5,278
    58
    Re: What the hell is happening to my headlights?
    Have you tried a headlight kit to see if it is on the outside? Hard to tel from the photos if it is on the inside or outside.
    Possibly even trying a polish (plastx) or compound (ultimate compound) before trying a headlight kit.
    Detailing my Black VW
    Apr 2010
    UK
    437
    It looks like condendation on the inside & is perfectly normal. My Mk7 Golf would do this.
    It will dry out it's self.
    Rappy
    Apr 2007
    US
    1,060
    22
    It looks like condensation on the inside, however it is NOT perfectly normal. There is a leak allowing moisture in. It probably will dry out itself, but the leak should be found and sealed. Otherwise, it will eventually stain. Go on an owners forum web site for your particular vehicle, there may be more information or even a recall for leaking lights. While I have not had the problem for my particular brand, according to some posts on the owners forums, the dealers did fix some, and for others there were plenty of DIY fixes.
    Jan 2017
    miami
    76
    I'm still under bumper to bumper warranty, so I will take it to the dealer and see what they could if they can replace the headlights, that's be great, but who knows what excuse they may give, id have to fight it, but is a 2014 and on both headlights? and only the upper part, it already had this when i bought it used, but it wasn't much and it has gotten worse without me doing anything directly to the headlights
    Apr 2010
    UK
    437
    It all depends on the make of car. My Golf R did this & it was common on the Mk7 Golf forum.
    It's the only car I have owned, that had this issue.
    My SQ5 & previous VW's never did this, so I guess it's down to the headlight design only.
    Rappy
    Registered Member Joe Dragon's Avatar
    Denver foothills
    530
    Definitely take it back to where you bought it.
    Registered Member Purple Towel Detailing's Avatar
    Sep 2015
    Aurora, Illinois
    16
    3
    Absolutely NOT normal for a headlight to not be sealed from moisture.
    Purple Towel Auto Detailing
    @purpletoweldetailing
    Apr 2010
    UK
    437
    Quote Originally Posted by Purple Towel Detailing View Post
    Not entirely true. The Golf had ventalation holes & was not completly sealed. I'm guessing to displace the heat from LED's.
    Rappy
    Apr 2007
    US
    1,060
    22
    Quote Originally Posted by Cogos View Post
    Headlight assemblies are very expensive, so expect a good fight from the dealer. If it is the original factory warranty, you might have a chance. If it is an extended warranty, well, in my opinion, those are practically worthless. Whatever the case, fight like h ell, because they are not supposed to allow moisture in. Good luck to you.
  1. Hell Knight
    By Skuz in forum Detailing 101
    Last Post: Sep 17th, 2011, 03:29 PM
  2. What is happening to my paint?
    By Miketphoto in forum Detailing 101
    Last Post: Nov 9th, 2010, 03:17 AM
  3. Lot's happening this week!
    By Mike Phillips in forum The Break Room
    Last Post: Apr 30th, 2007, 11:37 AM
  4. Whats happening?
    By Ronrazz in forum Detailing 101
    Last Post: Apr 28th, 2006, 09:35 AM
  5. Watermark hell!! Help
    By TheGuitarGuy in forum Detailing 101
    Last Post: Dec 11th, 2005, 03:36 PM
