Results 1 to 10 of 13
Thread: Piano Black Jamo Speakers
    Mar 2011
    Bahrain, Persian Gulf
    45
    7
    Hi everyone,
    I am doing quite well with car detailing but now I need your advise for detailing my home theater speakers system. I have Jamo speakers "Concert Series" in Piano Black.
    http://www.jamo.com/speakers/floorstanding/?sku=C109
    I noticed my subwoofer has some fine swirls and I am attaching some photos for reference.
    https://ibb.co/iuyx7v
    https://ibb.co/i6KgZa
    https://ibb.co/huY8Ea
    https://ibb.co/ieEgZa
    https://ibb.co/enyVSv
    https://ibb.co/myJ8Ea
    Currently have UC, UP, UW, ColorX and yellow foam pads. Which one should I use that will help without being aggressive, and any techniques to follow?
    Thanks
    2011 Maxima Satin White Pearl QX3
    2012 Renault Clio RS200 Liquid Yellow
    Meguiars G220 v2 DA Poliser
    Registered Member Joe Dragon's Avatar
    Denver foothills
    520
    Re: Piano Black Jamo Speakers
    I would contact the manufacturer to see if they have any recommendations; don't want to make matters worse.
    4,587
    53
    Hi iMak, we would agree with the above response, we would start by contacting the manufacturer and getting more details. I would recommend asking for more information on the finish itself, any proper care recommendations for the finish, as well as if they approve the use of mild abrasive cleaners for swirl removal.
    With that said, our M3416 Final Inspection, M09 Swirl Remover 2.0, and M07 Show Car Glaze have been used on hi gloss black painted instruments with success. The situation you have with your speakers appears to be similar to an instrument, a hi gloss paint on a wood substrate. If you were to try to use our automotive products to address the swirls & improve the gloss, these are the products which have been used in the past. They may work great but we suggest talking with the manufacturer first & doing a test spot. I would suggest applying with a soft foam applicator pad like our W0004 Soft Foam Applicator pads and removing with a quality microfiber towel like our X2020 Supreme Shine Microfiber Towel.
    800-854-8073 ext 3845
    Mar 2011
    45
    7
    Hi guys, thank you for your replies.
    I contacted the manufacturer and waiting for their reply. Will report back accordingly.
    @Nick W​inn
    As I stated in my opening post, I only have the mentioned products and I don't have access to the products you recommended.
    Mar 2011
    45
    7
    So, here is the communication with the manufacturer through their support center...
    Me:
    I have Jamo C109, C103, C93, C10 CEN & J112 SUB and when I was doing the routine cleaning I found some swirls on the subwoofer and the towers. I contacted Meguires for some advise on which products to use without damaging the paint, and they advised my to contact the manufacture.
    I would like to ask for more information on the finish itself, any proper care recommendations for the finish, as well as if you approve the use of mild abrasive cleaners for swirl removal.
    Jamo:
    We usually recommend using an ammonia based cleaner such as windex. Please let us know if you have any further questions.
    Thanks,
    Me:
    Thank you for your reply. But I think windex is good for general cleaning and in my case I use optics cleaner which is doing quite good. But for swirl removal I don't think it's going to work. What is the paint finish, is it a hi gloss black painted wood with a clear coat? More info on the paint finish will be helpful.
    Jamo:
    We used a typical hi gloss paint with clear coat. If you're having swirls on your finish, you may want to try using a wax solution like you would use to polish a cars finish. That would help get the swirls out.
    Let us know if that helps at all.
    Thanks,
    Am I ok to use the products I specified? Please advise.
    4,587
    53
    Quote Originally Posted by iMAK View Post
    I think you are going to be OK but it is really going to just be a matter of doing a test spot to see how it works. Try to apply in an inconspicuous area at first. It is good to know they use a "typical high gloss paint with clear coat." If that is the case then you should be fine.
    Registered Member Lydia's Avatar
    Dec 2005
    Fernandina Beach, FL
    27
    946
    22
    I recommend starting with ColorX or UP (ColorX would be the first I'd try) on the yellow foam pads (assuming you mean hand applicator pads) and work it in well. These both have light cut. As always, try to maintain even pad pressure if you're working by hand. Don't press harder with your fingertips. Work the product in well, then lighten pressure for the last several passes. Wipe it off and see how it looks. I recommend doing a test spot first to dial in the correct process.
    Lydia's Mobile Detailing
    2007 Honda ST1300 - Silver
    Nov 2004
    SoCal
    2,280
    39
    Cool Re: Piano Black Jamo Speakers
    A couple things to keep in mind.
    Loudspeaker finishes are meant to sit in your living room and look pretty. They aren't meant to take the same sort of exposure and abuse automotive finishes. They tend to be far less durable. So Lydia's advice to start with very mild products and processes is spot on.
    The edges on loudspeakers are waaaaaayyy sharper than the edges on auto bodies. It is much, much easier to burn through the finish on the edge of a speaker. Avoid polishing the edges. Mask them if you want to get close.
    Polishing products are mostly water based. Speaker cabinets are usually made of materials like MDF, which doesn't like getting wet. Don't get all heavy and splashy with the polishes. Keep them to the finished surfaces and avoid unfinished areas like the openings for drivers and wiring terminals. Avoid getting polishes on the drivers (especially the tweeters) altogether.
    Mar 2011
    45
    7
    @Nick Winn
    @Lydia
    @the other pc
    Thank you all for your productive advises and recommendations. You are a real help to the community. I will carefully work on it and share with you the good results.
    Mar 2011
    45
    7
    All turned out good. Excellent restoration. I applied UP with hand using the yellow foam and finished it with a coat of UW. No signs of swirls, all gone.
    https://ibb.co/mAZbcv
    Thank you for your advice.
  1. Piano black gloss interior trim nightmare
    By Oliseles in forum Interior Care
    Last Post: Jan 16th, 2017, 05:43 PM
  2. piano black trim
    By cm2005300 in forum Detailing 101
    Last Post: Mar 17th, 2015, 11:33 PM
  3. Best Combo for Piano Black. (UWP + GCCP + GCCPQW)
    By miataaa in forum Detailing 101
    Last Post: Sep 25th, 2013, 04:42 AM
  4. Speakers
    By Eddie6th in forum The Break Room
    Last Post: Aug 28th, 2009, 06:31 AM
  5. Speakers
    By wayne864 in forum The Break Room
    Last Post: Jan 16th, 2009, 10:48 AM
