Results 1 to 2 of 2
Thread: Meguiar's Headlight Restoration Products
    4,588
    53
    Clouded, yellowed, & oxidized headlights are all too common these days. Not only do headlights in these conditions diminish the look of a vehicle, they can also be a safety concern when driving at night. New replacement headlight lenses can be a few hundred dollars or in some cases thousands of dollars per headlight lens assembly. This article will give you some insight on why headlights oxidize, and also how a user has the ability to restore them with Meguiar's headlight restoration products.
    Headlight lenses from new come with with a high UV inhibiting clear coat paint which is applied to the exterior of the headlight lens assembly. A combination of UV degradation from the environment as well as micro pitting from the road take a toll on the coating over time, and lead to it diminishing, which leads to a clouded, yellowed, & oxidized headlight. Most of the time these defects are on the exterior of the headlight lens assembly. It is much less common to encounter defects on the inside of the headlight lens itself.
    Meguiar's headlight care products utilize specialized cleaners, abrasive technologies, and synthetic polymer protectant coatings. These work to remove the oxidized appearance & restore the lens assembly back to clear clarity.
    Choosing which Meguiar's Headlight Restoration Product to use comes down to personal preference of working by hand or power drill, and also the severity of the oxidation on the headlights.
    Meguiar's G12310 PlastX Clear Plastic Cleaner & Polish can be applied by hand for light oxidation. All that is needed is an applicator/towel and a little elbow grease. It can also be applied with a dual action polisher or rotary polisher for even more cleaning ability. PlastX is also included & used in the process of both our G2960 Basic Headlight Restoration Kit & G2980 Heavy Duty Headlight Restoration Kit.
    If you are looking to work strictly by hand, don't mind putting in a little time, and want to save on cost, Meguiar's G2960 Basic Headlight Restoration Kit is a good option. For more information on using Meguiar's Basic Headlight Restoration Kit, click on the following link: Using Meguiar's G2960 Basic Headlight Restoration Kit
    Meguiar's G2970 Two Step Headlight Restoration Kit consists of a two step "clean & coat" process, requires no buffing with a drill, and with results which provide 1 year of protection (*Lab tested per ASTM G154-12a). For more information on using Meguiar's Two Step Headlight Restoration Kit, click on the following link: Using Meguiar's G2970 Two Step Headlight Restoration Kit
    Meguiar's G2980 Heavy Duty Headlight Restoration Kit is a system of components which can handle even severely oxidized headlights. This kit also contains Meguiar's new "wipe on" liquid Headlight Coating. The liquid format makes application of the coating easy & also provides 1 year of protection (*Lab tested per ASTM G154-12a). For more information on using Meguiar's Heavy Duty Headlight Restoration Kit click the following link: Using Meguiar's G2980 Heavy Duty Headlight Restoration Kit
    If you have new lights or are using a different method to restore them, Meguiar's G17804 Keep Clear Headlight Coating can be used to protect them, and provides protection for 1 year(*Lab tested per ASTM G154-12a). For more information on using Meguiar's Keep Clear Headlight Coating click the following link: Using Meguiar's G17804 Keep Clear Headlight Coating
    Meguiar's is excited to announce that our G2970 Two Step Headlight Restoration Kit, G2980 Heavy Duty Headlight Restoration Kit, and G17804 Keep Clear Headlight Coating all include technology which provide protection for one year, Lab tested per ASTM G154-12a.
    Below is our video which highlights the features & benefits of our latest headlight restoration kits.
    When using any of our headlight restoration products be sure to read & follow the directions on the product packaging, and use this article for a reference.
    800-854-8073 ext 3845
    4,588
    53
    Re: Meguiar's Headlight Restoration Products
    *bump* new article with overview of Meguiar's 2017 headlight care products
  1. Using Meguiar's G2960 Basic Headlight Restoration Kit
    By Nick Winn in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: Jun 22nd, 2017, 08:46 AM
  2. Rough break up :(
    By buddy89 in forum The Break Room
    Last Post: Sep 27th, 2009, 10:16 AM
  3. Rough paint
    By thompsonjoshua in forum Detailing 101
    Last Post: Oct 31st, 2006, 03:39 AM
  4. Rough paint
    By festers in forum Detailing 101
    Last Post: Oct 7th, 2006, 06:07 AM
