Issues With Hazing When Using DA Power System and Ultimate Polish
  • Issues With Hazing When Using DA Power System and Ultimate Polish
    Ok so im pretty desperate for an answer and a solution as to why my whole hood has this haze/ foggy look to it? I covered it up with wax which helped a bit for now and i did not take pictures to post of the hazing before I applied the wax. Anyways, ive been into detailing for a wile now but have never attempted paint correction. I am lacking funds for my detailing arsenal so i purchased the DA power system with both burgundy and yellow pads along with ultimate compound(UC) and ultimate polish(UP). I have a 2016 Honda Accord with what i believe has soft paint. Thats also what ive found a lot of other Honda 9th gen accord owners to say as well. So i was pretty scared to attempt any type of paint correction on my Black car because i didnt want it to mar up the paint or have a dole look to it because it would definitely show on black. My car has very light scratches that can only be seen in certain angles in the sun. So i could have done without the paint correction for a bit longer but i wanted to do it so i can learn and also i have been obsessing over the minor imperfections in the paint.
    So this is what i did in the process:
    First my car was just a little dusty because it had been washed a couple of days ago and kept in the garage. So i used ultimate wash and wax anywhere to get the dust off the back panel that i was testing. Then i clayed the area.
    Next I started with the least aggressive option and used the yellow pad with the polish. I did just a very small area and went over with 4 passes going just a bit on the faster side but still at a steady pace. Then i wiped off residue with 20%IPA solution and it looked fine at the time.
    So next i did the same thing to my hood and trunk. I divided the trunk into 2 sections and the hood into 4 sections and did the same thing as i did on my test spot. (Oh and i applied 5 pea sized drops of polish on the pad each section).
    I used an air compressor to clean the pads after every other section.
    Next I went ahead and washed the whole car with chemical guys citrus wash and gloss with about a 1oz per gallon ration to strip any oil or wax so i can apply ultimate wax and then ultimate fast finish.
    After the wash i dried using a leaf blower and waffle weave towel.
    Then as im about to apply the wax to my hood i see the horrific hazing on the hood. It was also on the trunk and test spot. Idk what happened but im attempted to buy a porter cable and m205 to try and fix this but idk if it was my technique or not. Like i said i used 5 pea sized drops and made 4 passes on about a 2ft by 2 ft area. By the 4th pass some of the polish on the edges was a bit dry but for the most part there was still some moisture to it, if that makes sense.
    Any help would be greatly appreciated!!!
    Re: Issues With Hazing When Using DA Power System and Ultimate Polish
    I am thinking it is the IPA you are using to wipe off the polish residue. IPA is not a good lubricant. So it seems like you are seeing marring from the towel using IPA as well as the dull appearance.
    Go back and polish those areas. Wipe of those areas with a good microfiber towel and then just use ultimate wax. No need to remove the polishing oils as you are staying within the Meguiar's system.
    Also you should not need that much product for those small pads. Once primed, 2-3 drops of products is all you need.
    99 Grand Prix
    02 Camaro SS
      Sorry to hear about the trouble. I would have to agree with The Guz we do not recommended using IPA to assist in wipe off nor do we require using a product to strip all polishing oils before applying our waxes & sealants. If you are worried about our products filling in defects, our products are never engineered to fill and only have a very small natural ability to fill certain defects in some rare situations. I am not saying the product could not be contributing to this but I can't recall us ever having someone experience this much trouble, especially with just the polish step.
      How much pressure would you say you are applying during this step? What speeds is the drill rated at?
      I might suggest working the Ultimate Polish in a little longer if you give it another attempt. Especially now that you have this haze from something, working the polish in a little longer will allow the cleaner/polish ability of Ultimate Polish to assist in removing the haze by further refining the paint & bringing up a high gloss.
      - Nick
        What kind of clay and lubricant did you use. Hondas will easy mar with clay, especially if you had contaminants on the paint.
