Hi Nicholas, anything to do with using my new MT320 polishing machine on my Balck van please for the best results? Also is there such a thing as a sealer to use after I have polished & waxed my van?
Washing the vehicle is first of course. From there, it would be best to evaluate for any bonded above surface contaminants. This can be done by feeling the paint to inspect if it feels rough when the paint is clean & dry. If it does feel rough, it would be recommended to use our Smooth Surface Clay Kit. From there, evaluate for any swirls or scratches by inspecting under good lighting. If there are swirls & scratches present, our Ultimate Compound on your MT320 would work great on either the Red Cutting or Yellow Polishing Pad, depending on how much "cut" you need. From there our Ultimate Polish is a recommended step to maximum gloss, especially for black vehicle, and this can be used on either a yellow or black foam disc. Follow with your favorite coat of wax and you good to go! Compound & Polish are applied in small 2 ft square areas at a time. Hope this helps!
Irvine, CA nawinn@meguiars.com
