Will using UWWA or ONR on my glass mess up my Rain-X coating or boost it?
  • Will using UWWA or ONR on my glass mess up my Rain-X coating or boost it?
    I've really gotten into the waterless/rinseless wash method now and I know that these products can be used on glass. However, will using this over glass that already has a coating of Rain-X mess it up or will it help it (similar to using a spray wax over a base layer for added protection)? And does glass cleaner remove Rain-X? Thanks!
    Re: Will using UWWA or ONR on my glass mess up my Rain-X coating or boost it?
    For UWWA, you will more than likely see the effects of the product versus the rain x on the glass. It won't remove it but it will eventually be replaced by UWWA protection left behind. It is my understanding that ONR contains polymers in it as well. Although I can't comment on whether or not it leaves anything behind on the surface to alter the surface tension. Both won't remove rain x. I'm not sure it really matters if rain x is replaced seeing as it's effects are short lived.
    A glass cleaner that does not contain any alcohol should be ok. Something like Meguiar's Perfect Clarity, Stoners Invisible Glass should be fine.
    99 Grand Prix
    02 Camaro SS
      I do it all the time... base of RainX, use UQW while drying, so over spray everything. Never had a problem.
        Did you notice an improvement in the water beading properties at all? Did it bead more/run off sooner when driving in the rain?
          No.. I wouldn't say better or worse, but I keep it pretty clean all the time, clay one in a while.
