So I have super degreaser on hand and was wondering if would be an effective cleaner for plastic and rubber trim on the. Exterior of a vehicle to remove residue, dirt and oxidation prior to dressing it.
D108 to clean trim???
Re: D108 to clean trim???
Originally posted by ERICTSKI View PostSo I have super degreaser on hand and was wondering if would be an effective cleaner for plastic and rubber trim on the. Exterior of a vehicle to remove residue, dirt and oxidation prior to dressing it.
10:1 might work on trim. I have never used D108 for trim. Only for wheel wells. D101 should be in your arsenal as well.
I believe the Guz aka Michael is suggesting D108 at 10:1 for trim or maybe a weaker dilution.
But with D101, 4:1 is for really dirty conditions whereas 10:1 is great for well maintained trim.
I too have only used D108 for wheel wells, rubber floor mats and occasionally my tires"STRIFE" aka Phil
Originally posted by ERICTSKI View PostYeah sounds like d101 is needed. Was trying to keep my product numbers down but that's ok.
So are you suggesting D101 at 10:1 or 4:1 for exterior trim?Originally posted by STRIFE View PostI believe the Guz aka Michael is suggesting D108 at 10:1 for trim or maybe a weaker dilution.
I use D108 at 4:1 on tires as that is the only way it is effective at cleaning tires from me using it. I will use the same dilution for wheel wells.
