D151 + Megs 2015 thin polishing pads
  • D151 + Megs 2015 thin polishing pads
    This is how its supposed to be done, right? Just making sure. Cause I read that AIOs are supposed to be used with polishing pads. I wanted to get LC CCS Smart pads green, but wanted thinner pads.
    Re: D151 + Megs 2015 thin polishing pads
    Yep the megs thin pads will work fine with D151. Actually you can adjust the level of cut/finish based on your pad choice.
      I completely agree. If you need more cut you can go with the new burgundy pad. This can be said for most AIO's on the market.
      99 Grand Prix
      02 Camaro SS
        Yep, it depends what you're trying to achieve.
        Are you using D151 more for it's waxing / LSP properties, or for it's correction ability?
          More for paint correction. On a friends black scion TC. I ordered 12 pads from AG, all yellow flat. I already have black waxing pads.
          Would working the D151 for a longer time produce more cut? Like more section passes. This would be my first paint correcting by the way.
            D151 uses super micro abrasive technology (SMAT), non-diminishing, so long buffing cycles are not necessary. It has pretty good cut ability. Of course you could do another section pass with the product if more defect removal is needed. As always, avoid dry buffing.
            You could also do another round of D151 polishing by switching to less aggressive pad in second step, for example round one with cutting or polishing pad and round two with finishing pad.
            It's still my favorite all-in-one product.
              Try it with a polishing pad first. If it works then continue. If you need more cut then go to a cutting pad.
              99 Grand Prix
              02 Camaro SS
