Hello All,
As the title states. Can Meguiars M105 compound be mixed with such as M205 in creating a slightly less abrasive compound or in extending its working time on a rotary buffer using Meguiars Soft Buff 2.0 red cutting pads? Can water be misted on the surface with M105 without making to much of a mess?
Otherwise, can you recommend something similar to M105 that has a longer buffing time, which isn't prone to swirling, that can be used with a rotary buffer and stated cutting pads? It can be slightly less aggressive than M105 but needs to be a good first step compound for M205.
Note: I have a Meguiars DA that I will be using with Meguiars M205 to finish out. I just need something that can be used with a rotary buffer and cutting pads as the first step in removing light to moderate scratches.
Thanks,
Ralph
Thanks,
Ralph
