Can any soap be used in a foam gun? Could I put say ult wash and wax or gold class in there or does it have to be a concentrated solution?
foam gun
Re: foam gun
Originally posted by chrisalvarez View PostCan any soap be used in a foam gun? Could I put say ult wash and wax or gold class in there?
Re: foam gun
Originally posted by The Guz View PostYes you can use either one. You just need the proper mixture in the foam gun and you are good to go.
Re: foam gun
If you want to use a foam canon, or the specialized soaps, you can get the thick clingy foam.
The hose end Gilmour kind with Meguiars soaps are more like washing panel by panel as normal. But you can keep adding more soap and water to the panel as needed.
As for math.. if you get the Gillmor foamaster kind... 4 to 5 ounces of soap, filled with water, then on lowest dilution setting gets you to a little over the recomended 128:1.
At that ratio, no worse wax stripping than normal.
Not sure if uw&w could clog it more easily.2017 Subaru WRX Premium - WR Blue
Re: foam gun
Originally posted by chrisalvarez View PostYes but what if you already have decontaminated and have a well maintained vehicle? Will the soap you mentioned strip off protection?
Originally posted by chrisalvarez View PostThank you sir. So what would u suggest as the proper ratio? I have never used a foam gun and I typically use the two bucket (grit guards ofcourse ) method or the Garry Dean wash method which basically combines a rinselss wash and a waterless wash. But it is winter here in the Midwest and the Garry Dean wash method just doesn't feel safe on that level of grime so I need a traditional wash and I think a foam bath in addition will help tremendously in breaking down and washing away heavy dirt and grime before I wash by hand
Pretty good guideline here.
Autogeek is your number one car care source for auto detailing supplies, the best car wax, car care products, car polishes, auto accessories, polishers, and car detailing tools store.
Originally posted by Murr1525 View PostIf you want to use a foam canon, or the specialized soaps, you can get the thick clingy foam.
Re: foam gun
Re: foam gun
It'll kind of look like this...
if I use too much soap in the foam gun will it strip off the Americana ? With that in mind .... I put 2 cap fulls of carwash in the foam gun, is that enough or should I have used more ? after you foam up the car ( did it in the evening on a cool car ) how long do you let it sit before doing the 2...
So I spray one panel, catch the suds with the mitt and wipe around.. rather than standing back and letting it all run off. Trying to keep my lubrication all on the panel while wiping it.2017 Subaru WRX Premium - WR Blue
Re: foam gun
Re: foam gun
I too have also been considering getting a foam gun. This thread helped answer a question I had of what soap could be used as I have a gallon of Megs car wash Shampoo. Looks like that should work ok in a foam gun.2017 Lexus RX 350 - Satin Cashmere Metallic
2016 Honda Odyssey Touring - Crystal Black Pearl
2010 Ford F150 Lariat 4x4 - Royal Red Metallic
