We have streamlined our pad and backing plate choices for rotary use with the following line up:
This is the same pad as the So1o heavy cut wool pad, just with a part number change.
Again, essentially a part number change to what was the W4000 wool cutting pad.
Utilizing an all new foam construction, designed to run cooler but actually cut better than any of our previous burgundy colored foam cutting pads.
Unchanged from our previous foam pads, but utilizing a new laminate system to secure the loop material to the foam.
Another change in foam formulation, but with better finishing qualities than any of our previous foam finishing pads.
Two backing plate options: a standard "hard" backing plate for additional cut when needed, and a softer, thicker plate for finishing or working on more delicate paints.
This handy chart guides you through pad selection for rotary use.
