First of all thanks for reading.
2004 350z Magnetic Black, lots of swirls but very reflective and good color. Its garaged all the time, I used to wash it incorrectly until I watched Junkman and his vids.
I have wanted to fix the swirls for a while so I bought the da power system, did a test run on a honda hood, that came out perfect. Wash (2 bucket), clay, UC, Red bottle Polishing compound and yellow wax.
I started the 350z resto. on Labor Day weekend. Full 2 bucket wash, full day to clay, used DAPS (dual action power system) on passenger side hood near windshield, 1.5 ft x 1.5 ft area. Hit with UC first, went okay not all swirls removed did get water spot out, tried UC again and it hazed. I worked the product until started to turn clear, then wiped. The haze showed up on the edges of the work area.
I hoped UP would remove the haze but it did not. I made two attempts making 4 passes cross hatch. UP did take care of the swirls, couple of scratches left but later for them. The haze is not leaving. BTW, I'm in a gararge but not climate controlled and humidity was up. IMHO I think the work area was too large and the temps forced the product to dry early.
Should I get some M205 to remove the haze or keep working with UP? I know not to go back to UC. Is it okay to mix professional with ultimate products.
Is it fixable? or do I stop now, go with Show Car Glaze 7 and yellow wax and call it a draw.
I was a little surprised this happened but maybe too much pressure or too fast of the pad may have run dry.
Please advise and thanks in advance.
Tell Nick at the Meguiars help line thanks for his advice on what to purchase.
JJ
JJ
