ok to us wash&wax anywhere prior to UC,UP, & ULW
  • ok to us wash&wax anywhere prior to UC,UP, & ULW
    Wanted to know if its ok to use wash&wax anywhere to clean car as oppose to traditional pail and water prior to using the following
    1. Ultimate compound & water spot remover
    2. Ultimate polish
    3. Ultimate liquid wax
    I will be using the da power system thanks
    Re: ok to us wash&wax anywhere prior to UC,UP, & ULW
    Sure, that sounds perfectly fine.
      It will be fine. The amount of protect wash & wax leaves behind will not hinder you to use your method. UC and UP will prep the surface for UW. Also be sure to do the baggie test to see if you need to clay.
      99 Grand Prix
      02 Camaro SS
        Yes, it's a Wash. It washes your car.
        DetailingByM.com
